Results 1 to 5 of 5
    Junior Member
    philk's Computer Details
    Window 7 Enterprise
    6gb
    AutoCAD LT 2006
    Feb 2006
    Leicester, England
    12
    Default adding numbers to numbers
    Hi there,
    Can anyone help me. I have roughly a thousand datum levels which all need to be increased by the same number as the bench mark has changed. Does anyone know of a lisp routine that can carry out this.
    All help is very much appreciated.
    Cheers
    Phil k
    Senior Member
    AutoCAD 2008
    Nov 2005
    Bulgaria, Sofia
    228
    Do you have a block with attributes for each bench in your drawing?
    Junior Member
    Window 7 Enterprise
    6gb
    AutoCAD LT 2006
    Feb 2006
    Leicester, England
    12
    Hi there,
    Unfortunately not, its all single line mtext.
    Senior Member
    AutoCAD 2005
    Dec 2005
    Brandon, Manitoba, Canada
    166
    I can get the text entiy and read it value and add some number to it, but I'm not sure how to write a value back to the object.
    Code:
    ;Written by: Kevin Petursson
    ; February 23, 2006
    (defun c:addto (/ what where scale blockname tryagain insertpoint whatlength ll ur)
        (setq what nil)
        (print "Select text...")
        ;set the ammount to add to the base number
        (setq adding 15)
        (setq what (ssget))
        ;get name of the block
        (setq whatlength (sslength what))
        (setq whatlength (1- whatlength))
        &#40;while &#40;<= 0 whatlength&#41;
          &#40;setq textvalue &#40;cdr&#40;assoc 1 &#40;entget&#40;ssname what whatlength&#41;&#41;&#41;&#41;&#41;
          &#40;setq number &#40;atof textvalue&#41;&#41;
          &#40;setq number &#40;+ number adding&#41;&#41;
          ;write the value back to the object
          &#40;setq whatlength &#40;1- whatlength&#41;&#41;
        &#41;
      &#40;princ "all done"&#41;
      &#40;princ&#41;
    &#41;
    Hopefully someone else is a little more helpful.
    Thalon
  5. #5
    Junior Member
    Window 7 Enterprise
    6gb
    AutoCAD LT 2006
    Feb 2006
    Leicester, England
    12
    Default Eureka
    This guy deserves a Nobel prize!
    It works a treat.
    Thanks for reading and helping.
    Philk
    ; ************************* DP2.LSP *****************************
    ; Program to select required text (on a layer called LEVELS only)
    ; and change the numerical part of each text item by adding or
    ; subtracting a user-entered value. 20 May 1998
    ; Version 3 Modified to convert negative number values
    ; Written by Colin Browning
    (Defun *ERROR* (MSG)
    (Princ "Error: ")
    (Princ MSG)
    (Princ)
    ; *** SUB-ROUTINE TO UPDATE NUMBER VALUE:-
    (Defun Processit ()
    (Setq NUM1 nil)
    (Setq TLa (Strlen T2a)) ;calc string length
    (Setq KNT 1)
    (Setq PRE "") ;initialise prefix store as an empty string
    (Repeat TLa
    (Setq C1 (Substr T2a KNT 1)) ;check each char
    (Setq C2 (Ascii C1)) ;get ascii value
    (If (Or (< C2 45)(> C2 57)(= C2 46)(= C2 47));if not a number
    (Progn ;char or a minus sign then...
    (Setq PRE (Strcat PRE C1)) ;build prefix string
    (Setq KNT (1+ KNT))
    ) ;end of Progn
    (Setq NUM1 (Substr T2a KNT)) ;else get remaining number
    ) ;end of IF
    ) ;end of Repeat
    (If NUM1 ;check if number element exists
    (Progn
    (Setq TLb (Strlen NUM1)) ;calc no. of chars in number string
    (Setq NUM2 (Atof NUM1)) ;convert string number to a real
    (Setq TLc (Strlen (Itoa (Fix NUM2))));calc no. of chars in integer part
    (If (= TLb TLc) ;calc no. dec places
    (Setq TLd 0)
    (Setq TLd (- TLb TLc 1))
    ) ;end of 1st IF
    (Setq NUM3 (+ NUM2 V2)) ;update number value as a real
    (Setq NUM4 (Rtos NUM3 2 TLd)) ;convert back to string
    (Setq T2b (Strcat PRE NUM4)) ;add back prefix code if any
    ) ;end of Progn
    (Setq T2b PRE) ;Else re-use prefix if no no. element
    ) ;end of outer IF
    (Princ)
    ; *** MAIN FUNCTION:-
    (Defun CP2 ()
    (Graphscr)
    (Initget "Global Manual")
    (Setq S1 (Getkword "\nSelect text Globally or Manually (G/M) <Globally>: "))
    (If (Null S1)(Setq S1 "Global"))
    (If (= S1 "Global")
    (Setq S2 (Ssget "X" (List '(0 . "TEXT")'(8 . "LEVELS"))))
    (If (= S1 "Manual")
    (Setq S2 (Ssget (List '(0 . "TEXT")'(8 . "LEVELS"))))
    (If S2 ;if valid selection...
    (Progn ;then do this...
    (Initget 1)
    (Setq V2 (Getreal "\nEnter value to change levels by: "))
    (Setq L2 (Sslength S2)) ;calcs how many items selected
    (Setq CNT 0) ;initialise counter
    (Repeat L2 ;loop thru each
    (Setq N2 (Ssname S2 CNT)) ;gets entity name
    (Setq A2 (Entget N2)) ;gets assoc data listing
    (Setq T2 (Assoc 1 A2)) ;extracts text sub-list
    (Setq T2a (Cdr T2)) ;extracts actual text item
    (Processit) ;sub-routine to change text values
    (Setq A3 (Subst (Cons 1 T2b) T2 A2)) ;subst modified text value
    (Entmod A3) ;update drawing
    (Setq CNT (1+ CNT)) ;increment counter
    ) ;end of Repeat loop
    ) ;end of Progn
    (Prompt "\nNo valid selection. Try again!");Else option if no selection
    ) ;end of IF function
    (Princ) ;exit cleanly
