Results 1 to 7 of 7
    Senior Member tennis4you's Avatar
    tennis4you's Computer Details
    Windows 7
    GIGABYTE GA-G41MT-S2P LGA 775
    2 Duo E5700 3.0GHZ
    4 Gigs
    evga g210 1gb ddr3 pcie lp dvh
    500 Gigs
    External
    (2) 23" Monitors
    AutoCAD LT 2012
    Apr 2011
    Ohio
    240
    Default Fraction Stacking Question
    I initially told AutoCAD to stack all of the fractions but I think I have since changed my mind. Where is that setting that I can turn it off in my template file so all new files will not stack fractions? I assume that setting will disable it for text and dimensions?
    Thanks!
    Full Member
    AutoCAD 2010
    Jan 2011
    35
    Open the dimension style manager >modify >primary units (tab): linear dims: pick the choice you want from the pull down list.
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Double-click the Stacked Text, highlight the stacked text in the Mtext editor, and choose "Stack Properties" from the right click menu.
    Forum Newbie Mohawk's Avatar
    Mohawk's Computer Details
    Windows 7
    Intel Core i7
    16 GB
    Intel Graphics Media Accelerator (GMA) HD Graphics
    320 GB HDD
    AutoCAD 2014
    Dec 2010
    Minneapolis, MN
    6
    There is not a system variable. It is stored in the registry under the MText node (HKCU).
    You change it if you had accidentally specified "Do not ask".....
    Initiate the MTEXT command and make a boundary window for text anywhere, type a fraction, after it autostacks, highlight just the stacked fraction and right click it, select Stack Properties which is right below Unstack in the right click menu, once the properties come up, select the autostack button and there you can specify which behavior you prefer.
  5. #5
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    From the department of redundancy department.
    Drafting is a breeze.
  6. #6
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,096
    Quote Originally Posted by RobDraw View Post
    Haha, that gave me a good laugh Rob.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  7. #7
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Yeah, sorry, Mohawk, I couldn't resist.
  1. How do I make fraction look like this
    By marlon in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Aug 2009, 07:52 am
  2. trouble entering fraction of an inch
    By berol in forum AutoCAD Beginners' Area
    Last Post: 5th Apr 2009, 02:52 pm
  3. Horizontal fraction
    By Bane in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd May 2008, 01:07 am
  4. Text Override with fraction
    By edwin in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2006, 03:35 pm
  5. %%201, %%202 and so on.... Fraction Dimension
    By richjenn03 in forum AutoCAD Drawing Management & Output
    Last Post: 28th Feb 2005, 10:51 pm
