Results 1 to 10 of 10
    Junior Member
    Mauser's Computer Details
    XP Pro
    ASUS
    Intel Dual Core E6300 1.6ghz
    4gig DDR2 800
    ATI HD 5850 1GB
    Western Digital 320BG Internal BUFFALO 1TB External
    22" Samsung 2253BW
    AutoCAD 2010
    May 2010
    Ontario, Canada
    24
    Default FATAL ERROR: Unhandled e06d7363h Exception at fcdba49dh
    *potential solution for the error described below was to switch my Win7 desktop theme from an Aero theme to a basic theme, I chose classic. I am able to click the "open" icon on the toolbar over and over without triggering the error. If I switch back to Aero themes, the first click on the "open" icon triggers the error. Hope this helps.*
    This error:
    had been occuring every once and awhile the past couple months, but in the last week it has started to happen all the time. Typically it's when I am working on one .dwg and click the "open" icon to open another drawing. Same thing when I go File-Open. I think it has happened out of the blue while drawing but have been unable to trigger it during testing. *edit* after trying many times, I seem to be able to use the command line "open" to get to other files without triggering the error.
    Autocad 2010 64bit installed
    Win 7 64 bit
    Microsoft.NET Framework 4.0 Client Profile (as displayed in Programs)
    I mention framework because many similar errors (but not the exact same) have been linked to Net Framework.
    There is no match for this exact error on the Autocad help forums, so here I am.
    Thanks
    Gus
    Senior Member
    AutoCAD 2010
    Aug 2009
    Baltimore, MD
    111
    Found this via Google:
    http://www.wiki-errors.com/wiki-erro...wiki=e06d7363h
    I wasn't impress of what it had to offer for a fix.
    At the bottom it speaks of AutoCAD.
    Junior Member
    XP Pro
    ASUS
    4gig DDR2 800
    ATI HD 5850 1GB
    22" Samsung 2253BW
    AutoCAD 2010
    May 2010
    Ontario, Canada
    24
    Well, the one thing that link supports is the suggestion that these types of errors may be linked to a damaged .dll file, see link below:
    http://usa.autodesk.com/adsk/servlet...linkID=9240817
    The only other similiar description of my error I did find on the Autodesk site which is described as:
    http://forums.autodesk.com/t5/AutoCA...h/td-p/2679375
    *edit*
    also sounds similar to this problem, which is addressed by some regisrty editing:
    While none of these match the exact description of my error, they all seem very similar.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,154
    I would first search for the problem something like "File Open Fatal Error" on Autodesk or CADTutor etc. forums and "AutoCAD File Open Fatal Error" on Google, Bing, etc.. Then search for the FATAL ERROR: Unhandled e06d7363h Exception at fcdba49dh info if you can't solve the problem.
  5. #5
    Junior Member
    XP Pro
    ASUS
    4gig DDR2 800
    ATI HD 5850 1GB
    22" Samsung 2253BW
    AutoCAD 2010
    May 2010
    Ontario, Canada
    24
    Those 3x links are the fruits of many hours of searching those strings in those locations.
  6. #6
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,154
    I searched all those and found tons of info. Pretty much just a few solutions. Follow the advice on repairing the registry or do a complete uninstall and reinstall. Are you running any registry cleaners? What about your Virus protection?
  7. #7
    Junior Member
    XP Pro
    ASUS
    4gig DDR2 800
    ATI HD 5850 1GB
    22" Samsung 2253BW
    AutoCAD 2010
    May 2010
    Ontario, Canada
    24
    You found tons of info other than the 3x links I posted for you? Could you link me to that additional helpful information other than the registry solution I already posted?
    I have the registry open but have not made the change yet. My Hiword value is set to '0' while my Loword value is set to '4dde549e' which I could change to '0', if I understood the solution correctly.
    I've uninstalled - reinstalled.
    No registry cleaners running, antivirus is Avast V.5.0.677
    Thanks for your help so far!
  8. #8
    Junior Member
    XP Pro
    ASUS
    4gig DDR2 800
    ATI HD 5850 1GB
    22" Samsung 2253BW
    AutoCAD 2010
    May 2010
    Ontario, Canada
    24
    Tried the registry edit, error still occurs.
    Have determined that it's only the toolbar "open" icon that triggers the error.
    I can ctrl+o and use the command line "open" over and over without the error, but anywhere from the 1st to maybe 6th click of the toolbar "open" icon triggers the error.
  9. #9
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,154
    Glad you figured it out. I have turned all my Win 7 extras off.
    You should update your computer details, some, myself included look on the profile and computer details for info, sometimes forgetting what was written in the first post.
  10. #10
    Junior Member
    XP Pro
    ASUS
    4gig DDR2 800
    ATI HD 5850 1GB
    22" Samsung 2253BW
    AutoCAD 2010
    May 2010
    Ontario, Canada
    24
    Ahhhh I see what you mean, I totally forgot that I had included that system info in my profile. Will update to reflect my new system, thanks for the heads up.
  1. FATAl ERROR: Unhandled e06d7363h exception at 7629fbaeh
    By kippax in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 27th Mar 2010, 11:07 pm
  2. fatal error: unhandled e06d7363h exception at 7c812aebh
    By chelsea1307 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 9th Apr 2009, 01:10 pm
  3. FATAL ERROR: Unhandled e06d7363h Exception at 7c812a5bh
    By papagyi in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 19th Sep 2008, 12:32 pm
