+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Forum Newbie
    Using
    3ds Max 2011
    Join Date
    May 2011
    Posts
    1
    Default polysurface question
    Is it possible to join two separate solid objects (closed polysurfaces). I have a fairly strait forward flat plate (box) like solid and a second similar solid with the same thickness which has been twisted 90 degrees like a twizzler running alongside the first solid. the twisted object begins flush with the side of the flat one and gradually twists away until it is at a 90 degree angle from the box at which point it is only touching the adjacent box at one corner. imagine ,if you will, as i bend the object it cracks away from being flush with the box. what I wish to do is in this position, fill in this gap that opens up wide on one side and is closed at the other by some kind of fillet ,join,merge, connect command. i have tried all of the above with no success. any direction you can provide will be greatly appreciated.
  2. #2
    Full Member
    Using
    AutoCAD 2009
    Join Date
    Jan 2009
    Posts
    57
    Default
    First explode the polysurfaces and then use the blend surface to join them
    http://www.youtube.com/watch?v=b4ssn...eature=related
Similar Threads
  1. Replies: 1
    Last Post: 23rd Nov 2010, 02:27 pm
  2. Question
    By Signs in forum AutoCAD Beginners' Area
    Last Post: 27th Jun 2009, 02:27 am
  3. command line up arrow question, and grip edit distance question
    By Rebel in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2008, 03:15 pm
  4. 3D to 2D question
    By Winfield in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jun 2007, 09:21 pm
  5. question
    By Raul Ramirez in forum AutoCAD Beginners' Area
    Last Post: 3rd Feb 2006, 04:30 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
