Change multiple Dimensions measured text into normal text?
apsonwane
Is it possible to change measured text in multiple dimentions to normal text in one command, so that when objects are scaled or streched, dimention text value dosn't change anymore?
In short I am looking to convert dimention to number text.
Thanks in advance,
Ashish
Check this out .
(defun c:Test (/ ss str)
 (if
   (and
     (setq str (getstring T "\n Enter Text:"))
     (setq ss (ssget "_:L" '((0 . "*DIMENSION"))))
    (command "_.DimEdit" "_New" str ss "")
Tharwat
I don't understand why you would want to do such a thing? :?
This would accomplish the task...
(defun c:test ( / ss i e )
 (if (setq ss (ssget "_:L" '((0 . "*DIMENSION"))))
     (entupd
       (cdr
         (assoc -1
           (entmod
             (subst
               (cons 1
                 (LM:GetDimensionString (setq e (ssname ss (setq i (1- i)))))
               (assoc 1 (setq e (entget e))) e
(defun LM:GetDimensionString ( dim / dl db ds )
 (if
   (and
     (wcmatch (cdr (assoc 0 (setq dl (entget dim)))) "*DIMENSION")
     (setq db (tblobjname "BLOCK" (cdr (assoc 2 dl))))
   (while (and (setq db (entnext db)) (not ds))
     (if (eq "MTEXT" (cdr (assoc 0 (setq dl (entget db)))))
       (setq ds (cdr (assoc 1 dl)))
 ds
you could...*shudder* *gasp* *swallow* explode the dimension....
I was going to suggest that but decided I didn't want a moderator telling me off. :whistle:
Thanks Le Mac once again. :)
This is exactly what I was looking for.:D
The reson why I need this is, I always need to enlarge some portion of drawing in same sheet where I scale that portion of drawing keeping same dimention values.
Cheers,
Ashish
Cheers,
Ashish
That's why paper space layouts and "annotative scaling" was introduced so that you would not have to go through that. Why aren't you using the features built into 2010 to your advantage? You might as well be using AutoCAD release 9.
(defun c:test  (/ selset Units DimValue DimValue DimPrec)
     (vl-load-com)
     (if (ssget '((0 . "DIMENSION")))
                 (vlax-for
                        Text  (setq selset
                                         (vla-get-activeselectionset
                                               (vla-get-activedocument
                                                     (vlax-get-acad-object))))
                       (setq Units (vla-get-UnitsFormat text)
                             DimValue (vla-get-measurement text)
                                  DimPrec  (vla-get-PrimaryUnitsPrecision
                                               text)
                       (vla-put-TextOverride
                             text
                             (if (or (= Units 3)
                                     (= Units 4))
                                   (rtos DimValue
                                         4
                                         DimPrec)
                                   (rtos DimValue
                                         2
                                         DimPrec)
                 (vla-delete selset)
Not thouroughly tested
That is correct :)
Be aware that by using that method you will also have to account for DimPrefix, DimSuffix, Display of Alternate Units (and position [before/after primary]), AltPrefix, AltSuffix, AltUnits, AltPrecision, Tolerance Display, Tolerance types/justifications - oh, and not to mention any other MText formatting that the user has applied.
o:)
o:)
Or anything the user just manually typed in, in addition to the .
o:)
I totally agree with those mentioned above, there's way too much factors to consider alright.
:D
