Results 1 to 2 of 2
    Senior Member Raudel Solis's Avatar
    Raudel Solis's Computer Details
    Windows 7
    Hp dv7 4073nr
    Core i7 720 Qm
    6gb Ram 2/6
    1Gb Ati 5650
    500 Gb internal Hd
    500 Gb External Hd
    Built in & 32" External Hd Monitor
    Architectural
    3ds Max 2013
    Nov 2010
    Arlington Texas
    475
    Default BackBurner Manager
    ok so i have 2 computers 1 has 3ds max 2012, the other has 3ds max 2011.
    am i able to do a distributed bucket render?
    i am not sure if the computers communicate
    i got it set up correctly so i dont need help with that, i just need to know whether or not those to versions of max can work together in distributed bucket rendering
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    Depends on which version of Max created the file and which version of Max is controlling the rendering. Max is not backwards compatible, so if you created the file in 2012, your 2011 version will not be able to read the file. But if you created the file in 2011, and 2011 is controlling the render, you probably won't have any problem. But then again, maybe you will. I've never tried using two different versions on a render farm.
    But why don't you just load 2011 or 2012 on both machines? You can load Max on as many as 10 machines, (more than 10 will require the "Manager" machine to be a Windows Server), as long as you don't try to activate or use the other installations. The copies that you load on the other machines are just used for the purpose of rendering only, so they don't need to be activated.
    You may want to read through these:
    http://usa.autodesk.com/adsk/servlet...linkID=9241177
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  1. Backburner
    By Kobbe in forum Cameras, Lighting & Rendering
    Last Post: 4th Jun 2011, 04:43 am
  2. UCS manager
    By jenlozier in forum Autodesk Software General
    Last Post: 21st May 2011, 05:55 am
  3. Error after upgrading from backburner 2008.1 to 2008.1.1
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 4th Nov 2010, 02:30 am
  4. CAD Manager
    By AEKDB5 in forum CAD Management
    Last Post: 18th Jun 2009, 06:30 pm
