vnanhvu Posted June 3, 2011 Share Posted June 3, 2011 I have some drawing, but someone modify textdim. I usually "dimedit" > "home" for change textdim is changed become actual value. Who is faster to do it ? Thank all ! Quote Link to comment Share on other sites More sharing options...
troggarf Posted June 3, 2011 Share Posted June 3, 2011 Here is one that my teacher found online and used on us in class to correct any dims that people modified. It corrects any dimoverrides automatically. ;|TIP1149.LSP: ORG.LSP Original Dimension (c)1995, D.A. Longhenry Original Dims.LSP Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 3, 2011 Share Posted June 3, 2011 That seems a bit overkill with very little, if no, error trapping. There is no need to change any SystemVariables and furthermore, those that are changed in the code won't be reset if the user hits Esc at the prompt (a likely scenario considering the frequency with which most users punch the Esc key). Also, there is no check for a valid SelectionSet and no SelectionSet filter either. I know its not your code, I just wanted to point out the above points. I would approach it this way: (defun c:test ( / ss i e ) (if (setq ss (ssget "_:L" '((0 . "*DIMENSION") (1 . "*?*")))) (repeat (setq i (sslength ss)) (setq e (entget (ssname ss (setq i (1- i))))) (entmod (subst (cons 1 "") (assoc 1 e) e)) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
troggarf Posted June 3, 2011 Share Posted June 3, 2011 Cool Lee simple-sweet-and to the point ~Greg Quote Link to comment Share on other sites More sharing options...
vnanhvu Posted June 3, 2011 Author Share Posted June 3, 2011 Thank all thank cadtutor very much ! Quote Link to comment Share on other sites More sharing options...
