Tyke Posted June 3, 2011 Share Posted June 3, 2011 I'm running Microsoft Visual Studio 2010 on computers with XP and Vista 32 Bit and W7 64 Bit and have installed the ObjectARXs 2010 to 2012. I have also installed the AutoCAD VB.NET Application Wizard (Jerry Winters). When I want to start a new project, for example a Windows Forms Application, it works perfectly in all three situations. If I select either an AutoCAD Managed VB Project Application or an AutoCAD VB.NET Application I have no problems in the XP and Vista 32 Bit environments, but on the W7 64 Bit machine I get an error message " ... project creation failed." I've tried changing the location of things and adjusting the entries in the *.vsz files but all without any success. I first thought it might have something to do with the "Program Files" or "Program Files (x86)" folders, but it doesn't seem to have any influence on things. Has anybody else encountered this problem, or does anyone know of a solution, Quote Link to comment Share on other sites More sharing options...
Jeff H Posted June 3, 2011 Share Posted June 3, 2011 Maybe you can try this. With Win7 I have noticed this with about everything I download. Once you download the ObjectArx files and BEFORE you unzip them or run the exe right-click on the folder and select properties then select the 'unblock' button. I had problems with 64-bit templates and that solve it for me The pic is from downloading a dwg Quote Link to comment Share on other sites More sharing options...
Tyke Posted June 3, 2011 Author Share Posted June 3, 2011 Thanks for the tip Jeff, I didn't know about the unblock button. I tried it out but unfortunately it didn't change anything. Quote Link to comment Share on other sites More sharing options...
SEANT Posted June 5, 2011 Share Posted June 5, 2011 I notice that VBCAD has two separate templates for 32 and 64bit. . . . I haven’t used the one from VBCAD, but is it derived fromthe wizard discussed here? http://through-the-interface.typepad.com/through_the_interface/2009/06/a-new-project-wizard-for-autocad-net-development.html http://through-the-interface.typepad.com/through_the_interface/2010/08/new-version-of-the-autocad-net-wizard-posted.html Quote Link to comment Share on other sites More sharing options...
Tyke Posted June 5, 2011 Author Share Posted June 5, 2011 Thanks for the information SEANT. The 64 Bit template from VBCAD is working and I've downloaded the one from Kean Walmsley's blog. I'm having a little trouble with the installation (user rights!) but I'll get that sorted out. Quote Link to comment Share on other sites More sharing options...
