Results 1 to 4 of 4
    Forum Newbie
    Map 3D 2011
    Jun 2011
    2
    Default MAP pull-down missing from classic menu bar
    This is my first post anywhere so please excuse me if I am not following the correct protocol.
    I am a AutoCAD Map 3D 2011 user. After one of our IS people worked on my PC to correct an issue with my web brouser (probably unrelated to my current problem but strangely coincidental don't you think?) I find that I am missing the MAP pull-down from the Map Classic Workspace. Can someone help me restore it? I have the other menu items (File, Edit, View Insert, Format, Tools, Draw, Dimension, Modify, ?, Window, Raster, Express) but the MAP field is missing.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,042
    I moved your question to the MAP3D forum.
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    You can try to restore it or reset it from the CUI, type CUI at the command line to get to it.
    Murph
    Need a boat or camper for the weekend?
    Forum Newbie
    Map 3D 2011
    Jun 2011
    2
    That did it! Thanks for the help Murph.
  1. Block Pull down menu
    By natsha61 in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Jan 2011, 04:46 pm
  2. Pull down menu check
    By deano33 in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Feb 2010, 08:50 pm
  3. Make an Image Tile Menu from Pull-Down Menu
    By sumski in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Nov 2009, 12:08 am
  4. Classic View/Menu
    By SoggyCashew in forum AutoCAD General
    Last Post: 21st Sep 2008, 08:39 am
