Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Full Member
    AutoCAD 2012
    Jun 2011
    44
    Default Can't edit unlocked layers. How to change default viewport scale list.
    I just started using 2012. Two problems:
    1- Somehow, in my current drawing, everything is layer-locked. There are no Xrefs in this very basic drawing. All layers are unlocked. Yet, any attempt to select any entities results in "x objects were on a locked layer". Again, all layers are unlocked. No Xrefs. No blocks. Just simple lines. All entities appear faded. This happened after viewing a layout in both paper and model spaces. Reviewing the text window shows no strange accidental commands.
    2- There is a default set of viewport scales in the status bar at the bottom right. Default scales are all metric. I would like both metric and imperial. I see you can edit which exact scales are in a metric list, and which are in an imperial list. But how do you set what is displayed/available in the status bar button?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Can you post the drawing you are having a problem with?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,097
    Sounds like you have isolated your layers.
    Full Member
    AutoCAD 2012
    Jun 2011
    44
    Layers were indeed isolated. Thanks. I knew it would be something simple. Just not up to speed with 2012 yet.
    And now the other problem remains:
    2- There is a default set of viewport scales in the status bar at the bottom right. Default scales are all metric/eng. I would like both metric/eng and imperial/arch. I see you can edit which exact scales are in a metric list, and which are in an imperial list. But how do you set what is displayed/available in the status bar button?
  5. #5
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,097
    _SCALELISTEDIT works in 2011.
  6. #6
    Full Member
    AutoCAD 2012
    Jun 2011
    44
    Default How to change default viewport scale list
    Quote Originally Posted by SLW210 View Post
    Well, I got that far. But that way, you have to manually enter every single scale from scratch. Surely there is a way to add the scales that are already defined.
    Has anyone else figured this out?
  7. #7
    Super Member qball's Avatar
    Structural
    qball's Discipline Details
    Structural
    Structural / Architectural, Residential, Multi-family, Industrial, Wood frame, Steel, Masonry, Concrete, Tilt-up
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    Do it once, and add it to your default template.
    How many are there if you open up a new drawing? I don't remember populating the Scale List ever. So I assume there were many in the Autocad package.
    I don't have a catchy signature
  8. #8
    Full Member
    AutoCAD 2012
    Jun 2011
    44
    Quote Originally Posted by qball View Post
    Just the metric/eng ones. About 17.
    I'm guessing I'll have to do as you said, but I try to be optimistic and am always looking for one click solutions vs multiple actions. Particularly when dealing with advanced software. Maybe someone has the magic wand?
  9. #9
    Structural
    Structural
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    Wait a tic... you're saying that your Edit Drawing Scales (Scalelistedit) doesn't match the Annotation Scale button??
  10. #10
    Full Member
    AutoCAD 2012
    Jun 2011
    44
    Oh, it matches. But if you go Options/User Preferences/Default Scale List, you will find metric and imperial listed separately. I would like to have both available at all times. I'm in Canada and switch back and forth constantly and can even sometimes have layouts with both.
  1. Making ANNOTATION SCALE and Viewport scale the same by default
    By mvrcad in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th May 2011, 02:35 pm
  2. Default Scale List 2011
    By richie_008 in forum AutoCAD Beginners' Area
    Last Post: 13th Nov 2010, 10:33 pm
  3. Scale List Edit
    By Jaelin in forum Civil 3D & LDD
    Last Post: 28th Jul 2009, 10:31 pm
  4. Edit Scale List
    By Alan Cullen in forum AutoCAD Drawing Management & Output
    Last Post: 14th Apr 2009, 12:08 am
  5. can't edit or select objects in an unlocked layer
    By Statick in forum AutoCAD Beginners' Area
    Last Post: 12th Mar 2005, 09:05 pm
