Results 1 to 5 of 5
    Senior Member
    AutoCAD 2010
    Jun 2009
    205
    Default How to change plotstyles?
    When I plot to pdf, everything in my viewports is a gray light tone, hard to see. How do I change this?
    Super Member DANIEL's Avatar
    Mechanical
    DANIEL's Discipline Details
    Industrial
    Mechanical
    AutoCAD 2012
    May 2005
    Arlington Texas
    995
    you'll need a ctb file with all the colors set to plot black
    If you would like to help my 2 year old niece Alaina in her battle against Leukemia you can donate blood at any Carter Blood Care and put SPON050875 on the donor form. Thank you so much for any contributions in this matter that you can make.
    Luminous beings are we, not this crude matter.
    Senior Member
    AutoCAD 2010
    Jun 2009
    205
    Where do I get one of those?
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    976
    Your plot settings window should give you the option to select a different color table (in the "plot style table" combo box). You may have to expand the plot settings window to see it. Several color tables are provided with the basic AutoCAD package. Pick a table, look at the preview, and repeat until you find one that gives you results you like.
    breaking AutoCAD on a regular basis since 1991
  5. #5
    Mechanical
    Industrial
    Mechanical
    AutoCAD 2012
    May 2005
    Arlington Texas
    995
    Quote Originally Posted by Mason Dixon View Post
    I would suggest starting with the one you are currently using, under the field that allows you to select the plot style table select it then clcik the edit button to the right, this is where you can set the colors to black and do a save as, in fact you might want to do that to start with so you dont over write your currently used ctb file accidently.
  1. Can't edit plotstyles
    By kellert82 in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Mar 2011, 08:29 pm
  2. couldn't change the line weight of resistors, or change their color
    By jackson6612 in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2011, 12:10 pm
  3. When I change the color the dimensions change!
    By Mark Costantino in forum AutoCAD Drawing Management & Output
    Last Post: 12th Oct 2009, 05:55 pm
  4. How Change Line Length Depend On Attribute Value Change
    By MR MAN in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Apr 2009, 03:08 am
  5. Lineweights and Plotstyles
    By nikko_77 in forum AutoCAD Beginners' Area
    Last Post: 5th Mar 2004, 08:36 pm
