blackeagle1245 Posted June 14, 2011 Share Posted June 14, 2011 Can we arrange insulation layers?. Normally it just offets the layer that we used in pipe or in duct. I couldnt find any solution for this. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted June 15, 2011 Share Posted June 15, 2011 Sure. Go to Display Manager > Representations by Object > Pipe > Plan > Layer/Color/Linetype. Under the Display Component "Insulation", you can set the Layer, Color, Linetype, Lineweight, LTSCALE, and Plot Style (if you use STB). Quote Link to comment Share on other sites More sharing options...
blackeagle1245 Posted June 16, 2011 Author Share Posted June 16, 2011 Thanks a lot Quote Link to comment Share on other sites More sharing options...
tzframpton Posted June 16, 2011 Share Posted June 16, 2011 Also, be sure to save these settings in your Template file instead of just the current drawing and you'll never have to adjust new files started from here on out. Quote Link to comment Share on other sites More sharing options...
