ddave Posted June 15, 2011 Share Posted June 15, 2011 Hi I am working on piping plan. I have four differents pipes on same layer. I would like to change color of one pipe in active viewport and keep the layer color unchanged in same Viewport. I would like to keep the layer color unchanged for model space or other viewports. Is there any way to change the property of an object in active viewport? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
nestly Posted June 16, 2011 Share Posted June 16, 2011 I don't think there's any way to change the color of an individual object by viewport unless that object is on it's own layer. If that one "pipe" has to be displayed differentl than all the other pipes on that layer, then perhaps it should be on it's own layer anyway. Use whatever makes that pipe different than the other pipes to define the new layer name. For example create an additional layer with the same name except add an "X" for eXisting, or maybe a "P" or Proposed, or "D" for Demo, or "R" for Relocate... you get the idea. Quote Link to comment Share on other sites More sharing options...
ddave Posted June 16, 2011 Author Share Posted June 16, 2011 Thank you Nestly. Right now we have taken the route that you suggested. Thanks Quote Link to comment Share on other sites More sharing options...
