Results 1 to 4 of 4
    Full Member ORgrown's Avatar
    AutoCAD
    Apr 2005
    61
    Default Page Orientation Problem when Plotting (to printers/PDF)
    Using 2009 on XP Machine (svc pack 3).
    Imported an old profile to get all the pathways, etc for specifically a 3rd party design program. Looked like it was pointing to 2000 files so I edited to search in 2009. After I think it's ok, I'm trying to plot - a window view oriented in LANDSCAPE. 1) ACAD Warning pops up: "[plotter name](temporary).pc3: This plotter configuration cannot be used for one of these reasons: the driver cannot be found, the device cannot be found, or the driver has a problem. The None plot device has been substituted." *The plotters do exist and are in the control panel; I can print to them (just not the correct orientation), and they are on a server). 2) I select the plotter, go into Properties and: I change the orientation in the plotter set up (regardless of whether I'm plotting on the B&W 8-1/2x11 printer, the color HP Design Jet, or to PDF (using CutePDF)). Once it saves the temp .pc3 file, I preview and paper is still Portrait with window selection scaled down to fit that width.
    I'm thinking it's not mapped correctly to find the pc3 file for the plotters for ACAD applications. Is this done through Tools/Options? (Where?) And where should it map to? Am I on the correct thinking path?
    Thanks for any assistance! I'm attaching screen shots for review.
    ORgrown
    Senior Member
    AutoCAD 2015
    Sep 2010
    New Zealand
    217
    See the arrow in the bottom right hand corner next to help - press that - you will get more options
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,744
    I'd also advise creating a non-temporary PC3 file and setting hide system printers. That way you don't need to constantly change these settings. Windows drivers don't always work off the cuff with ACad, you sometimes need to modify some settings for ACad only - and if you do this in the PC3 file it doesn't affect other windows programs, but if you change the defaults on the windows driver you may simply have moved your problem to programs other than ACad.
    AutoCAD
    Apr 2005
    61
    Quote Originally Posted by Grant View Post
    Grant,
    Just so happens it was hidden when I did the screen shot, but yes, I was orienting the page correctly.
    I've since reinstalled 2009 due to some other oddities. I'm hoping this has resolved it.
    Thanks!
    ORgrown
  1. Create a page setup for plotting
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 7th Apr 2009, 04:00 am
  2. Plotting orientation
    By Skeeps in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jun 2008, 10:51 am
  3. Page Orientation when Plotting
    By JaketheMan in forum AutoCAD Drawing Management & Output
    Last Post: 6th Dec 2007, 02:54 am
  4. Plotting orientation problem
    By Siberian in forum AutoCAD Drawing Management & Output
    Last Post: 8th Mar 2007, 04:30 pm
  5. Plotting 2D and 3D on same page?
    By chieftanfeces in forum AutoCAD Beginners' Area
    Last Post: 27th Feb 2007, 03:05 pm
