Results 1 to 6 of 6
    Senior Member khoshravan's Avatar
    khoshravan's Computer Details
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    422
    Default A geometry question
    The circle C' with radius AB (r) and center B and angle alpha is given. I want to draw the triangle ABD in a way that CD=AB=r
    Is there a way to draw it in AutoCAD ?
    draw hexagon w compass and straightedge.dwg
    For those who are interested, this is a way to trisect the angle alpha. Angle CBD is the trisect of alpha.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,965
    Here is one way to draw it in AutoCAD.
    I had initial difficulty in identifying angle alpha, because it was not labelled in the drawing. However I have plumped for the angle so marked in my picture.
    I drew an arc alpha and trisected it by using Divide. I drew a line to the third point, and mirrored it about a vertical line through B. This line I extended to C. Then I drew a line from A through C and extended it to D.
    Check measurement reveals that C-D equals A-B equals r.
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    422
    sorry I forgot to label the alpha but your guess is correct.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,965
    This morning, I see where I could have shortened the process a bit.
    After drawing the line from B to the third point, then offset this line through A. Extend this line to the circle at A and the line to D.
  5. #5
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    422
    Wink
    Quote Originally Posted by eldon View Post
    Actually this is more of a geometry question. You may remember from geometry that there are a set of questions which should be solved with only compass and straightedge (ruler with no mark).
    Trisection of an angle is one of disputed questions which many believe that it is impossible to solve.
    Off course for CAD users it is sort of nonsense. I was trying to solve that question.
    If you are interested you can find more on http://en.wikipedia.org/wiki/Angle_trisection under item number 3.
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,965
    Quote Originally Posted by khoshravan View Post
    I know that the tri-section of an angle is a goal in geometry, and that was why, following your request to draw in AutoCAD, I was pleased to use facilities that are not available with manual means.
  1. Geometry disapears
    By Pikey8 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Jun 2008, 02:47 pm
  2. Geometry in Text
    By ankitcs in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2007, 02:12 am
  3. Geometry in Text
    By ankitcs in forum Autodesk Software General
    Last Post: 19th Oct 2007, 05:20 pm
  4. Geometry Problem
    By Rockero in forum AutoCAD Beginners' Area
    Last Post: 13th Jul 2006, 03:33 pm
  5. Scaling of Geometry> what do you do?
    By MGV in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Jul 2005, 07:32 pm
Tags for this Thread
