Results 1 to 5 of 5
    Senior Member khoshravan's Avatar
    khoshravan's Computer Details
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Default mirror cmnd in paper space didn't return expects results
    I thought by using mirror command in paper space I can get the mirror of my drawing, but it returns the same drawing.
    So if I want to have mirror of my drawing, first I have to mirror it in model space and then get the entire drawing in PS.
    Other commands, like copy, rotate, scale, affects whole model in PS but apparently rotate doesn't.
    Is there any key to change this behavior?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,646
    Mirror is mirror. What were you expecting? Mirror a drawing of your left hand it will look like a drawing of your right hand.
    Why would you think that mirroring your model space drawing would result in a mirror image in paper space? It does not work that way.
    What do you mean by "rotate" does not affect the whole model? What are you rotating? A viewport?
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Rotating my left hand drawing will show my right hand in model space but it doesn't show so in paper space. It just show left hand again.
    About rotate, yes I am rotating the view port and whole model visible in the viewport rotates with it. I know that it could be controlled by a cad command, namely VPROTATEASSOC. But mirroring a viewport doesn't bring the mirrored model. Just the border of the viewport is mirrored.
    Hope that I was able enough to express what I meant.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    You can get what you are looking for by changing the view within the viewport to "Bottom." If you want a top to bottom mirror, rotate that viewport 180 degrees.
    Drafting is a breeze.
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,583
    Quote Originally Posted by khoshravan View Post
    Newer releases of AutoCAD let you rotate the Viewport and the model will follow. Mirror on a viewport will still not work.
    To rotate a view in a viewport, while the vp is current, UCS, Z, 90. Plan, Current. This is one of several ways to do this.
    To mirror a view use UCS, Y, 180, Plan, Current.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. Bring Paper Space object through Viewport into Model Space
    By karenreeves in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Nov 2011, 08:58 pm
  2. 2011 AutoCAD - Setting my LTSCALE in Paper Space as the same it is in Model Space
    By Rage221677 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Dec 2010, 07:31 pm
  3. AcadPViewport2 - Deleting items in model space that aren't seen inside paper space
    By lovemy65stang in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2009, 05:26 am
  4. Replies: 0
    Last Post: 22nd Jan 2007, 10:20 pm
  5. 2006 space bar for return
    By wehaveaproblem in forum AutoCAD Drawing Management & Output
    Last Post: 16th May 2005, 05:31 pm
Tags for this Thread
