Steve_wright Posted June 19, 2011 Share Posted June 19, 2011 Can't figure out why my cogs are not going in the same way ..it seems to stop and start as well ?..anyone know what i have done wrong? or is it simply because my computer is not fast enough to keep up with the programs information. Hello by the way...... Excuse the fantastic vid...not the best one i have done for sure... Quote Link to comment Share on other sites More sharing options...
Steve_wright Posted June 19, 2011 Author Share Posted June 19, 2011 here's the sketches ect if you need them. master.zip mastercog1.zip mastercog2.zip CHAIN LINK 1.zip Quote Link to comment Share on other sites More sharing options...
nchaplin Posted June 20, 2011 Share Posted June 20, 2011 I have had some problems with this too what I did in the end to make sure I could tell what direction things were moving was to add a pattern to the surface of the moving parts (the Cog) and you sure be able to see a little better which way it is rotating. or simply add an extrusion offset from the centre of the cog and you will be able to see which way it is rotating. I think they are moving the same way but don't have time to look at your files (it might be the effect like when your cycling a bike and it looks like you wheel is rotating backwards if you know what i mean ) Quote Link to comment Share on other sites More sharing options...
DNK Posted June 20, 2011 Share Posted June 20, 2011 I think it's an illusion as well. Add a marker to verify. Quote Link to comment Share on other sites More sharing options...
