Guest JoeRoscia Posted June 20, 2011 Share Posted June 20, 2011 I've been experiencing a problem I just can't figure out. I have a drawing where I've placed some text with the Mtext command utilizing multi-leader. In one location I have text with the leader in the correct lineweight. In an other location on the drawing, on a different layer, more text (correct lineweight) with a leader so thin you have a difficult time seeing it when plotted. I used the same commands when contructing both sets of text and the only difference being their on different layers. In the layer manager both layer lineweights are set to "Default". Any ideas on hoe to fix this? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 20, 2011 Share Posted June 20, 2011 Check your plot style. If you are using a .ctb and those layers are different colors, you might be using different lineweights for them. Quote Link to comment Share on other sites More sharing options...
Guest JoeRoscia Posted June 20, 2011 Share Posted June 20, 2011 Checked them already-all settings are alike.... Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 20, 2011 Share Posted June 20, 2011 Can you post a file with those leaders? Quote Link to comment Share on other sites More sharing options...
Guest JoeRoscia Posted June 20, 2011 Share Posted June 20, 2011 I would but I just can't get under the maximum size requirements of this message board. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 20, 2011 Share Posted June 20, 2011 Make a file with just the leaders in question. I don't need anything else. Quote Link to comment Share on other sites More sharing options...
Guest JoeRoscia Posted June 20, 2011 Share Posted June 20, 2011 I did and I'm still over 475kb so the site won't allow me to upload the file... Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 20, 2011 Share Posted June 20, 2011 I sent you an email through CADTutor with an email address you can send it to. Let me know when you have sent it. Quote Link to comment Share on other sites More sharing options...
Guest JoeRoscia Posted June 20, 2011 Share Posted June 20, 2011 Sent it... Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 20, 2011 Share Posted June 20, 2011 Did you try Purging and Zipping the file? Quote Link to comment Share on other sites More sharing options...
Guest JoeRoscia Posted June 20, 2011 Share Posted June 20, 2011 Yes, I did both but Rob sent me an email address I could send the file to him. Thanks! Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 20, 2011 Share Posted June 20, 2011 Your .ctb file is set up to "Use Object lineweight" for all colors, so you have to assign them to the objects. The green ones have an assigned lineweight of 0.00 mm. The cyan ones are set to "By Layer." Pick one or the other according to your offices standards. Quote Link to comment Share on other sites More sharing options...
Guest JoeRoscia Posted June 20, 2011 Share Posted June 20, 2011 WOW, if I wasn't completely confused before I am now! Where do I find this info? I came from an office that plotted simply by color ie, red=very thin, yellow=thin, green=medium, cyan=thick, etc. Lines plotted at exactly the correct thickness and never-ever ran into these problems. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 20, 2011 Share Posted June 20, 2011 If this is new to you, you should check with your CAD manager for your office standards. You can find and change the lineweights in the properties box. Quote Link to comment Share on other sites More sharing options...
Guest JoeRoscia Posted June 20, 2011 Share Posted June 20, 2011 Rob- Thanks so much for your help! Not sure how the lineweight changed to 0.00mm but I was able to fix it. Thanks again for your time! Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 20, 2011 Share Posted June 20, 2011 You're very welcome. Quote Link to comment Share on other sites More sharing options...
