IsaacB Posted June 20, 2011 Share Posted June 20, 2011 Ok over the past few weeks I've got pretty much most of the Dynamic Block stuff down except this feature. I've attached a drawing. In the middle I used VISIBILITY to have all the different weld types. I need something at the end to where Weld Tails can be added if they're needed but you can only use one Visibility per block. I'm also going to need something at the front of the block for different symbols like "Field Weld" and "All Available". If I can figure the Tails out then I can do the other one. Does anyone have an idea on how to get this to work? WeldBlock.dwg Quote Link to comment Share on other sites More sharing options...
