Results 1 to 7 of 7
    Senior Member
    not applicable
    Jan 2008
    Littleton Colorado USA
    166
    Default Lisp tools for isometric drawing
    I recently had a need to draw isometric views to complement some 2D drawings
    with orthographic views. I was not familiar with Autocad's isometric snap
    mode, so I did some reading of help files and played with the related commands.
    It took some getting used to but after a while I was able to produce a passable
    isometric drawing. Along the way, it occurred to me that some lisp programs
    might be helpful with the isometric drawing process, so I wrote some. The
    attached zip file contains the collection of lisp tools and descriptions that
    may be useful. Feel free to modify the code any way you like.
    It will be argued that with the advent of 3D CAD it is unnecessary to draw a 2D isometric when it could be automatically produced by the software. But I'm pretty sure that there are still a lot of CAD users producing 2D drawings with little motive to learn to draw in 3D and a 2D isometric is appropriate for these drawings. I considered writing a short tutorial, but to avoid re-inventing that wheel I would suggest that if you are not familiar with isometric mode please browse to
    http://www.scribd.com/doc/49636065/1...etric-Drafting
    for a very nice introduction to isometric drawing by Ralph Grabowski.
    isotools_lsp.ZIP
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,744
    The problem with isometric is it's usually a bit difficult getting text and dims to look correct. You tend to have to modify individual dims/text to match the iso-pane you want them to "appear" in. E.g. using the DimEdit Oblique and draw a line in one of the ISO panes. Then you also might want the text to appear as if drawn isometrically (instead of orthogonally) by adjusting the Obliqueing property, but that requires some further mods for dims.
    Whereas if you draw directly on the 3d objects then the text & dims will also be drawn correctly as well. And if it's just a few lines (instead of true solids) you can still draw them in 3d.
    But it's up to you if you want 2d/3d drawings. And with something like those ISOtools you get around most of ISO's problems. You'll need some extras to get the text/dims things to work that way as well.
    Senior Member
    not applicable
    Jan 2008
    166
    Yes it's true that dimensioning in isometric involves a lot of setting up text and dimension styles. There is information about that in the link I provided. For my purposes, I only dimension in the orthographic views. The isometric is only for easier visualization of the parts for the shop people. If you need to do many isometric drawings and want more support than the isotools provide, you might want to look here :
    http://www.cwattsdesign.com/isomaker-pro.htm
    I'm not endorsing this software. I've not used it, but it appears to be professional level with a lot of options.
    Full Member 19cruthik68's Avatar
    Electro/Mech
    19cruthik68's Discipline Details
    Draftsman
    Electro/Mech
    AutoCAD 2012
    Sep 2011
    Doha, Qatar
    82
    CALCAD, where will i put those lisp files inside that zip folder? Actually dont have any idea about that but i heard it already, where is the exact location of the folder i will put those things and how will i launch it in autocad? thanks bro.
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Create a new folder and call it MyLisp or CustomLisp. Put any lisp routines you download or create in the folder. Then go to Options > Files and Folders and make sure the path to the folder is listed in the Support File Search Path. Autolisp routines can be loaded in a number of ways. One option is via the APPLOAD command. Other options explained here...
    http://lee-mac.com/runlisp.html
  6. #6
    Full Member
    kramerO's Computer Details
    N/A
    not applicable
    Oct 2010
    N/A
    36
    Thanks for sharing, CALCAD.
    Isometric and 3D are two different things.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Yes they are but it is possible to generate a 2D isometric view from a 3D object. You'll still have to apply the same principles when it comes to dimensioning the isometrics no matter what method is used to generate them.
  1. Need help in isometric drawing.
    By Valamu in forum AutoCAD Beginners' Area
    Last Post: 26th May 2010, 11:58 am
  2. Isometric Drawing help
    By DJ Hands3 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Feb 2010, 03:19 am
  3. I need help with an isometric drawing!
    By edbothma in forum AutoCAD Beginners' Area
    Last Post: 17th Feb 2010, 11:54 am
  4. Isometric Drawing pt. 2
    By J-Rod#1 in forum AutoCAD Beginners' Area
    Last Post: 4th Dec 2008, 09:34 am
  5. Isometric drawing
    By whel_13 in forum Catch All
    Last Post: 10th May 2003, 05:29 am
