Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 33
  1. #11
    Junior Member
    AutoCAD 2004
    Jun 2011
    11
    when I type ucs in the command line, it says "current ucs name: *NO NAME*. Below that, <World> is the default, so when I hit Enter, the ucs rotates so the X axis is pointing down and Y axis is almost horizontal, pointing slightly upwards. I dunno what's going on here.
  2. #12
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,139
    After that, type PLAN and hit Enter twice to realign the drawing view with the WCS.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  3. #13
    Junior Member
    AutoCAD 2004
    Jun 2011
    11
    Hey, that did it! So now I'm starting to see what this guy mighta did. Maybe somehow oriented the ucs and crosshairs to whatever he was working on in the drawing. It's very large, and the various objects are oriented at different angles. I was reading a little about this, but haven't quite got it yet. Anyone familiar with this? I just never ran across it before.
  4. #14
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,139
    I do it all the time. When a floor plan has non symmetrical layouts I will rotate the UCS around the Z axis then use the PLAN command to realign the drawing orientation.
  5. #15
    Junior Member
    AutoCAD 2004
    Jun 2011
    11
    Thanks. How do you do it?
  6. #16
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,139
    Type UCS, choose Z, then type in the rotation angle or pick two points. Then type PLAN and hit Enter twice to align the drawing orientation. To get back to normal, type UCS and hit Enter twice, then PLAN and Enter twice. Simple as that.
  7. #17
    Senior Member
    vertical horizons's Computer Details
    Windows 8 PRO
    DX79TO
    I-7 3820 @3.60 GHz
    16.0 GB
    AMD FirePro W7000
    16 GB
    ViewSonic VX2739wm (Primary) & HP w1907 (Secondary)
    Manufacture
    vertical horizons's Discipline Details
    Drafting Supervisor
    Manufacture
    not applicable
    Mar 2010
    Texas
    237
    Quote Originally Posted by Jack_O'neill View Post
    ... Here's where it gets really cool. No matter what scale you use in the viewport, if you put all your dimensions on in paperspace, they will all be the same size! Even if you change the scale, a regen will fix all the dimensions and they will be correct, and still be the same size ...
    Another tip ...
    Set DIMASSOC to "2".
    This will allow you to dimension (in paperspace) everything that you drew in modelspace, and it will dimension correctly.
    For example, you drew something true size (let's say 30 foot long) in modelspace. Looking at it in paperspace, your screen is not 30 foot long, so the item has to be looked at through a viewport. If you dimension the item (in paperspace) and DIMASSOC is set to "2", then even though the item is actually 30 foot long, the item will dimension correctly.
  8. #18
    Full Member emwhite's Avatar
    emwhite's Computer Details
    Win 7 Pro
    Lenovo w510
    Intel® Core™ i7-720QM (1.60GHz base; 2.80GHz Max Turbo, 6MB Cache)
    8GB (2 X 4GB) PC3-10600 DDR3 1333MHz
    NVIDIA® Quadro® FX 880M
    Intel 160gb SSD, Windows Home Server 5TB+
    Structural
    emwhite's Discipline Details
    Sales Support/CAD Monkey
    Structural
    Light gauge framing of homes.
    AutoCAD 2010
    Feb 2011
    Dallas, TX
    74
    Quote Originally Posted by StykFacE View Post
    Thank you for that tip! I didn't know about the PLAN command.
  9. #19
    Junior Member
    AutoCAD 2004
    Jun 2011
    11
    This is a good tip.The crosshairs and ucs look right, but now the whole drawing rotates somehow. Haven't figured this one out yet.
  10. #20
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Why is that a problem (rotated drawing)? Maybe that's why the UCS and crosshairs were rotated in the first place.
  1. 2011 AutoCAD - Setting my LTSCALE in Paper Space as the same it is in Model Space
    By Rage221677 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Dec 2010, 07:31 pm
  2. How to Freeze paper space dimension layer in model space
    By david1954 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th May 2010, 04:16 pm
  3. Drawing appears different in paper space than model space
    By dwelch in forum AutoCAD Beginners' Area
    Last Post: 19th Feb 2010, 12:35 pm
  4. AcadPViewport2 - Deleting items in model space that aren't seen inside paper space
    By lovemy65stang in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2009, 05:26 am
  5. Replies: 0
    Last Post: 22nd Jan 2007, 10:20 pm
