See IntersectWith Method.
I need to calculate a point along a polyline based on intersecting a point of a circle with a polyline the centre is always along the poly line but can intersect different segments.
The idea is to walk along the poly line calculating the other points.
I have written a VBA`routine which calcs points along the poly line but I am looking for an easy way to calculate the intersecting points.
Any one done something like this ?![]()
Just an example, not sure that will work what you needOriginally Posted by BIGAL
(all of this grabbed from adesk's and another forum)
~'J'~Code:Option Explicit Public Function Sel_Poly_Fence(oPoly As AcadLWPolyline) As AcadSelectionSet Dim vType(0) As Integer Dim vData(0) As Variant Dim selCol As AcadSelectionSets Dim oSelset As AcadSelectionSet Dim vPts() As Double Dim mode As Integer mode = acSelectionSetFence vType(0) = 0 vData(0) = "CIRCLE" Set selCol = ThisDrawing.SelectionSets For Each oSelset In selCol If oSelset.Name = "Fence_Sset" Then oSelset.Delete Exit For End If Next oSelset Set oSelset = ThisDrawing.SelectionSets.Add("Fence_Sset") If oPoly.Closed = False Then vPts = PointArray2dTo3d(oPoly.Coordinates) Else vPts = PointArray2dTo3d(Split_Coordinates(oPoly.Coordinates)) End If oSelset.SelectByPolygon mode, vPts, vType, vData Set Sel_Poly_Fence = oSelset End Function Private Function PointArray2dTo3d(vPts) Dim vNewPts() As Double Dim i As Integer Dim j As Integer ReDim vNewPts(CInt(1.5 * (UBound(vPts) + 1)) - 1) As Double j = 0 For i = 0 To UBound(vPts) Step 2 vNewPts(i + j) = vPts(i) vNewPts(i + j + 1) = vPts(i + 1) j = j + 1 Next PointArray2dTo3d = vNewPts End Function Public Function Split_Coordinates(oCoords As Variant) As Variant Dim retArr() As Double Dim i As Integer retArr = oCoords i = UBound(oCoords) + 1 ReDim Preserve retArr(0 To i + 1) retArr(i) = oCoords(0): retArr(i + 1) = oCoords(1) Split_Coordinates = retArr End Function Sub Test_Fence_Selection() Dim oPoly As AcadEntity Dim oCirc As AcadEntity Dim intArr As Variant Dim pntList() As Variant Dim varPnt(0 To 2) As Double Dim snapPt As Variant Dim oSelset As AcadSelectionSet Dim i As Integer Dim j As Integer Dim nCirc As AcadCircle On Error GoTo ErrHand ThisDrawing.Utility.GetEntity oPoly, snapPt, vbCr & "Select polyline :" If oPoly.ObjectName = "AcDbPolyline" Then Set oSelset = Sel_Poly_Fence(oPoly) Else: MsgBox "This object isn't a polyline!" Exit Sub End If j = -1 For Each oCirc In oSelset If IsEmpty(oCirc.IntersectWith(oPoly, acExtendNone)) = True Then Exit For Else intArr = oCirc.IntersectWith(oPoly, acExtendNone) For i = 0 To UBound(intArr) - 1 Step 3 varPnt(0) = intArr(i): varPnt(1) = intArr(i + 1): varPnt(2) = intArr(i + 2) Set nCirc = ThisDrawing.ModelSpace.AddCircle(varPnt, 1.5) 'change diameter by suit j = j + 1 ReDim Preserve pntList(j) pntList(j) = varPnt Next End If Next ErrHand: MsgBox Err.Description End Sub
Thanks for the help got it to work using intersect need to use an arc rather than a circle stops second answer being generated. others may be interested so here is some code to play with I have left the different options remarked ie line / line, line / arc, line /circle, poly lines etc
there are option on the AcExtend command so a little experimenting is needed.
Sub find_ints()
Dim opoly As AcadEntity
Dim oline1 As AcadEntity
Dim oline2 As AcadEntity
Dim ocirc As AcadEntity
Dim oarc As AcadEntity
Dim arcobj As AcadEntity
Dim retVal As Variant
Dim ptObj As AcadPoint
Dim Pt1(0 To 2) As Double
Dim circObj As AcadCircle
On Error GoTo Something_Wrong
'ThisDrawing.Utility.GetEntity oline1, snapPt, vbCr & "Select line :"
'ThisDrawing.Utility.GetEntity oline2, snapPt, vbCr & "Select line :"
'ThisDrawing.Utility.GetEntity ocirc, snapPt, vbCr & "Select circle :"
'ThisDrawing.Utility.GetEntity oarc, snapPt, vbCr & "Select arc :"
'select last arc drawn automaticaly
ThisDrawing.Utility.GetEntity.last oarc
ThisDrawing.Utility.GetEntity opoly, snapPt, vbCr & "Select polyline :"
'If opoly.ObjectName = "AcDbPolyline" Then
'Coords = opoly.Coordinates
'Else: MsgBox "This object is not a polyline!"
'xit Sub
'End If
'retVal = oline1.IntersectWith(oline2, acExtendBoth)
'retVal = oline1.IntersectWith(opoly, acExtendBoth)
'retVal = ocirc.IntersectWith(opoly, acExtendNone)
retVal = oarc.IntersectWith(opoly, acExtendOtherEntity)
MsgBox retVal(0)
MsgBox retVal(1)
GoTo endprog
Something_Wrong:
endprog:
End Sub
