f700es Posted June 23, 2011 Share Posted June 23, 2011 Dim style is set to scale dims to match vp but when I layout a dimension it is not correct. I ran the "dimreassociate" command and that fixes it but only on the dim that I fix/selected. What am I missing? This is an existing legacy drawing so there must be some setting that has been changed. TIA Quote Link to comment Share on other sites More sharing options...
f700es Posted June 23, 2011 Author Share Posted June 23, 2011 Argh!!!! As soon as I post I find it. "Dimassoc" was set to 1 instead of 2 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 23, 2011 Share Posted June 23, 2011 (edited) I wish I could help, I have all kinds of dimension problems with legacy drawings. I usually get it like I want in properties then matchprop the rest. The other way is to make a new dimstyle with all the settings and do a Dimension update. Argh!!!! As soon as I post I find it."Dimassoc" was set to 1 instead of 2 That was easy enough. Edited June 23, 2011 by SLW210 ...... Quote Link to comment Share on other sites More sharing options...
f700es Posted June 23, 2011 Author Share Posted June 23, 2011 WhyTF would you set it that way? 2 is the default. Yes legacy drawings are the pits. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 23, 2011 Share Posted June 23, 2011 Anyway, I am glad you mentioned that, I am once again in a legacy drawing and I checked... "DIMASSOC = 1" for some reason it always seems the case. Drawings saved in a format previous to AutoCAD 2002 retain the setting of the DIMASSOC system variable. When the drawing is reopened in AutoCAD 2002 or later, the dimension associativity setting is restored. If a legacy drawing is opened in AutoCAD 2002, the DIMASSOC system variable takes on the value of the legacy drawing's DIMASO system variable. Quote Link to comment Share on other sites More sharing options...
