Results 1 to 4 of 4
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, W8 + W8.1 Vista
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2014
    Jun 2006
    Saxony, Germany
    1,397
    Default Export linetypes to a *.LIN file
    Does anybody know if its possible to export linetype definitions from a drawing into an AutoCAD *.LIN (eg MyLines.LIN) file.
    There is a DWG that we need to work on for a client and we will later need to create some new drawings but using the client's linetypes and it would help if we had a *.LIN file.
    I could make a copy of the drawing that already has the linetypes in it, delete everything, purge everything except the linetypes and save it and insert the "empty" block/drawing into a new drawing. It works, but my original question still stands.
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,131
    You can scroll down to Similar Threads. There are lisps that do what you want.
    HP Z400 Workstation
    8 GB
    Multi-disciplinary
    Multi-disciplinary
    Civil 3D 2014
    Jun 2006
    Saxony, Germany
    1,397
    Quote Originally Posted by eldon View Post
    Thanks eldon, I had already done several searches but not found anything. I've downloaded the LISP routines and will give them a try next week.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,131
    As a linetype definition is part of the drawing, you should be able to extract the information straight from a DXF file. But better let the Lisp take the strain!
  1. Replies: 8
    Last Post: 17th Jan 2011, 12:27 pm
  2. Export/import drawing file to/from csv(text) file
    By mtjipta in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jan 2010, 04:14 am
  3. how shall i export dwg file to 3d max
    By sudhaathreya in forum 3D Modelling
    Last Post: 9th Oct 2009, 06:19 pm
  4. Can I get the linetype text file from imported linetypes?
    By spittle in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Jul 2009, 08:16 am
  5. Linetypes support file path
    By Organic in forum AutoCAD Beginners' Area
    Last Post: 24th Mar 2009, 10:06 am
