Results 1 to 3 of 3
    Forum Newbie
    Map 3D 2010
    May 2010
    9
    Default How do i change from 3dp to 2dp?
    I have a drawing with all levels at 3dp e.g 13.346, is there a way of changing all at once to 2dp e.g 13.35?
    Thank you,
    Craig
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,124
    I moved this to the Map3D Forum.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,968
    You do not say whether the levels are simple text or whether they are part of a block attribute.
    If they are simple text, there is a lisp called TextMath which will do what you want.
  1. couldn't change the line weight of resistors, or change their color
    By jackson6612 in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2011, 12:10 pm
  2. When I change the color the dimensions change!
    By Mark Costantino in forum AutoCAD Drawing Management & Output
    Last Post: 12th Oct 2009, 05:55 pm
  3. How Change Line Length Depend On Attribute Value Change
    By MR MAN in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Apr 2009, 03:08 am
  4. CHange UCS
    By SstennizZ in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Apr 2008, 10:10 am
  5. How will i change UCS
    By mericad in forum AutoCAD Drawing Management & Output
    Last Post: 8th Apr 2008, 02:52 am
