Keith_1978 Posted June 30, 2011 Share Posted June 30, 2011 Would like to see if anyone knows how to export points out of a drawing, that contains an alignment, with station numbers from that alignment? Trying to do this in Auto CAD Civil 3D 2010. The reason I need to do this, is due to being able to refrence the points back to a station number along the alignment, for example along a pipeline centerline. It should be able to export the points with station numbers to a .csv file or .txt file. Example: STA: 02+00 - POINT NO. 245, ETC. Any help to lead me in the right direction would be most helpful. Quote Link to comment Share on other sites More sharing options...
Murph_map Posted June 30, 2011 Share Posted June 30, 2011 Export to GIS Format (SDF) then use the analysis tools in MAP3D FDO. Quote Link to comment Share on other sites More sharing options...
sinc Posted June 30, 2011 Share Posted June 30, 2011 There's a "Station Offset to Points" report in the Toolbox that will generate a report. You can generate it in a variety of formats - html, Word doc, Excel xls, txt. Here's a sample of the output to xls: The two points in this report were set to "No Elevation" - I notice that gets reported in this report as a very bizarre value. The unlicensed version of the Sincpac-C3D also has a STAOFF command: http://www.quuxsoft.com/SincpacC3D_Help/SP_StationOffset.htm This is a lot like the "Display Points" command from Land Desktop. This command is available in the unlicensed version, so all you have to do is install the Sincpac-C3D and you can use it. (The licensed version has several ways to do much neater things along these lines.) Quote Link to comment Share on other sites More sharing options...
