ACADDOC.LSP file suddenly not working?!?
tzframpton
Got a real issue maybe. Here's what I've checked:
1. The path is correct in the Support File Search Path, and at the top of the list.
2. The paths are correct in the ACADDOC.LSP file and they are.
3. The LISP files which are pathed using the (load) command is correct, and they are.
If all these are correct, what could stop it from working? Any ideas?
(findfile "acaddoc.lsp")
Edit: You said the paths are correct in the SFSP, and within acaddoc.lsp, not where acaddoc.lsp is located according to ACAD.
Place at end of acaddoc.lsp file.
(princ "\n*** My acaddoc.lsp loaded *** ")(princ)
Hit F2 after opening a drawing and see if it tried to load.
AH............. Found the problem.
The first path in the ACADDOC.LSP file was broken. I updated a program from Lee Mac. Little did I know it would not skip over and load the rest of the paths!!! Ah, whew. I thought something really went wrong there, lol. Thanks a million once again guys. Man, just seemed so simple, sometimes I get mad at myself for not checking the obvious.....
