Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    Car5858's Discipline Details
    retired, disibality
    See details below.
    Tutor, AMA glider competitions.
    AutoCAD 2010
    May 2009
    Hammond
    373
    That is good advise Jack, Bracken2 I think you need to read over the instructions for direct input of lines from the command line. You may have the dynamic input toggle button on. This can cause some problems at times. Practice is what makes perfect, have you done a sketch first? Sketching allows you to put everything in order that you need to draw them. The PF instructions are not in the correct draw order, this is why you have to go over them a few times. Make little blocks next to each task on the instruction sheet, this way you can check them off as you complete them.
    Also at the bottom of the thread is Similar Threads These are other threads related to this project.
  2. #12
    Full Member
    AutoCAD 2010
    Jul 2011
    Ellijay, GA.
    72
    hi I'm back trying to fininsh this project, I have restart, I need to know how I connect my lots, 4,5,6
    lot 4 is south of lot 3 length of the western edge is 168.24 feet N55d24'29"E
    lot 5 is directly to the south of lot 4 the length of the western edge of lot5 is 69.10feet, the length of the southern edge of 5 is 156.48ft n1d15'21"w
    lot6 is directly to the east of lot 5, length of the southern edge is 162.27ft, notheasterly direction for 23.06, n50d43'14"w
    all lots the property line should intersect with the center of the cul-de-sac
  3. #13
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,731
    The southern lot line for all three lots runs parallel to the property line (boundary). Offset that line the required distance. That should get you started.
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,731
    bracken2: Have you made any further progress?
  5. #15
    Full Member
    AutoCAD 2010
    Jul 2011
    Ellijay, GA.
    72
    some, I still have a lot of problems understanding how to get coordinate input like going north, south, east or west, I have put in the lots that is 60 x 120 but the still do not look right. I have went back looking at some of the other qestion other are asking you, they are helping a little, I just know that I have to learn this some way.
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,731
    To draw a line that starts at a particular coordinate start the line command and when prompted "Specify first point" enter the coordinate like this...
    123556.78, 366927.14 then press Enter.
    If one or both of your boundary lines are drawn at the incorrect angle then when you offset them the result will be incorrect as well. The basis for the three lots that are 60x120 are the two boundary lines in the northwest corner of the property.
  1. need project help for penn foster oleson village
    By Firligic in forum Student Project Questions
    Last Post: 20th Mar 2017, 11:13 pm
  2. Penn Foster Oleson Village Project Check
    By Batman in forum Student Project Questions
    Last Post: 27th May 2012, 02:27 pm
  3. Penn and Foster Structural Project Help
    By robxfinch in forum Student Project Questions
    Last Post: 20th Nov 2011, 03:31 am
  4. oleson village question..
    By armydude2211 in forum Student Project Questions
    Last Post: 8th Feb 2011, 04:44 am
  5. Penn Foster Oleson Village drawing
    By black31 in forum Student Project Questions
    Last Post: 16th Dec 2010, 10:56 pm
