Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Quote Originally Posted by Strix View Post
    breaking hatching up (exploding) is an offence punishable by death in these parts
    Agreed, had an external dwg with this in it today.
  2. #12
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    Car5858's Discipline Details
    retired, disibality
    See details below.
    Tutor, AMA glider competitions.
    AutoCAD 2010
    May 2009
    Hammond
    373
    Quote Originally Posted by bracken2 View Post
    ok, the pic. help, but how did you break the hatching up
    Use the hatch command, and pic opposite quadrents top and bottom. By just picking 2 of the four quadrents your drawing will look like rendermans drawing. By changing the angle of the hatch in the dialog box, you change how the hatch is displayed. I advise you to use the preview button this will show you what it looks like before you accept it.
    Never explode hatches your asking for more problems then it is worth.
  3. #13
    Full Member
    AutoCAD 2010
    Jul 2011
    Ellijay, GA.
    72
    Unhappy
    Did you mean something different?
    Yes, I quess I did, by looking at the pic. you have two parts that has the hatching in them, that what I'Mm talking about,
    I'm A student in this class, I feel like these 6 project I need to finish is kicking me.
  4. #14
    Full Member
    AutoCAD 2010
    Jul 2011
    Ellijay, GA.
    72
    Thank you, I will try this
  5. #15
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,129
    hi,
    I have been working on this project, need help!!
    Benchmark 312, exists at the northwest corner of the survey area. it has a elevation of 88.9 feet and its coordinates are 521662,44895
    For the BM symbol, use a 10-foot diameter circle bisected by a horizontal line and a vetical line. it asking me to use hatch apttern ans131, scale 2, angle 45,slelct two
    points in the symbol,point within the northwest and southeast quarter of the symbol. I'm not able to do this, please help
    Those instructions seem clear and concise to me. What type of course is this? Are you just handed a book and expected to figure it all out.
    I have renamed your thread, please let everyone know what you are doing. No need to hide the fact you are a student, as a matter of fact, you will most likely receive more appropriate answers if your skill level is known.
  6. #16
    Super Member qball's Avatar
    Structural
    qball's Discipline Details
    Structural
    Structural / Architectural, Residential, Multi-family, Industrial, Wood frame, Steel, Masonry, Concrete, Tilt-up
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    If your units are in feet and inches it will look something like this:
    Code:
    Command: cc CIRCLE Specify center point for circle or [3P/2P/Ttr (tan tan
    radius)]:
    Specify radius of circle or [Diameter]: d
    Specify diameter of circle: 10'
    Command: l LINE Specify first point:
    Specify next point or [Undo]:
    Command:  LINE Specify first point:
    Command: h HATCH
    >> Forced layer S-HAT
    Pick internal point or [Select objects/remove Boundaries]: Selecting
    everything...
    Selecting everything visible...
    Analyzing the selected data...
    Analyzing internal islands...
    everything...
    Pick or press Esc to return to dialog or <Right-click to accept hatch>:
    Command:
    Command: *Cancel*
    Commands:
    CIRCLE (Diameter 10')
    LINE (Osnap to Quadrants)
    HATCH (Pick internal points, 2 of the 4 quadrants or chambers of the bisected circle, with the specified hatch pattern)
    fin
    edit: I only read the last post, not knowing it had been answered. I thought this was the thread from the other day where everyone was getting frustrated with lack of information.
    I don't have a catchy signature
  7. #17
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    If you get stuck - right click on the filename and select Send to Compressed (zipped) folder.
    Attach the resulting zip file here.
  1. HVAC School project
    By Autocadstudent in forum Student Project Questions
    Last Post: 16th Jan 2018, 08:08 pm
  2. school CAD project
    By bdr2k5 in forum Student Project Questions
    Last Post: 25th Apr 2010, 11:44 am
  3. I need an interviewee for a school project.
    By AlwaysLola in forum AutoCAD Beginners' Area
    Last Post: 9th May 2007, 02:33 pm
