fisher22 Posted July 6, 2011 Share Posted July 6, 2011 Hi, Im completly new to CAD so this is probably going to sound stupid but how would I find the distance between two offset lines. Basicaly what I have got is straight line with an original offset line at the base and I have copied this line at different distances along the line, but I need a way to double check the distances from the original line. Again sorry if it is really simple. thanks alot, Steve Quote Link to comment Share on other sites More sharing options...
nestly Posted July 6, 2011 Share Posted July 6, 2011 You have several options including: Distance command (DIST) and pick any two points MeasureGeometry command (MEASUREGEOM) from the Ribbon or the Command line, and pick any two points Create a dimension between any two points. Quote Link to comment Share on other sites More sharing options...
eldon Posted July 6, 2011 Share Posted July 6, 2011 Using Osnaps, the first pick point will be at the End, Middle or Near the line, and then for the second pickpoint, you must use Perpendicular to the second line. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted July 6, 2011 Share Posted July 6, 2011 This may help: (command "._dist" "near" pause "perp") Quote Link to comment Share on other sites More sharing options...
fisher22 Posted July 6, 2011 Author Share Posted July 6, 2011 Thanks alot sorted Quote Link to comment Share on other sites More sharing options...
