CyberAngel Posted July 6, 2011 Share Posted July 6, 2011 This is probably another one of those "quirks." I report it in the hope that, late in the 22nd century or so, someone will get around to fixing it. When I use Quick Select to find the objects on a particular layer, they are normally highlighted, and I can see the grips. Every so often that doesn't happen. I can still see the properties of the selection set, so the command has worked. If I select one of those objects, the rest are magically highlighted. Sometimes I select objects by layer simply to find out how many are there and where they are, so this particular quirk is frustrating. What makes it happen? If I knew, it would be a bug, not a quirk. At a guess, it happens after I've done several Quick Selects in a row. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted July 6, 2011 Share Posted July 6, 2011 Maybe it gets tired, and thinks "man, I wish this guy would make up his mind":lol: Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted July 6, 2011 Author Share Posted July 6, 2011 Maybe it gets tired' date=' and thinks "man, I wish this guy would make up his mind":lol:[/quote'] or the highlighter used by the little guy inside the box runs out of ink, and he has to go get another one ... Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted July 6, 2011 Share Posted July 6, 2011 Maybe there's a world wide grip shortage? Quote Link to comment Share on other sites More sharing options...
