Results 1 to 3 of 3
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    976
    Default PDF plotting mishap
    The boss wanted a PDF plotted, but not at the scale on the page. There's probably a better way to do it, but I did this:
    a) insert into AutoCAD as xref
    b) scale up to actual size
    c) plot with desired scale
    Only one problem. The sheet came out blank. The PDF xref looks white on my black Model Space screen, although it looks black on my white preview screen.
    The reason I'm posting this is because I found a way to make it work. Instead of plotting to paper, plot to another PDF. That way you'll know if it turns out blank. The only way I could get it to show up was to use the Plot Option
    (wait for it)
    Plot Transparency
    Update: when I rotate the PDF xref before plotting, AutoCAD crashes. One of those mysteries.
    breaking AutoCAD on a regular basis since 1991
    Super Member Organic's Avatar
    Civil
    Civil 3D 2013
    Feb 2009
    1,641
    I would have just scaled it using the scale function on a photocopier lol. Not a fan of inserting PDFs into drawings due to the problems with them.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,373
    When you go to print in the PDF choose a larger paper size, done.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  1. CAD 2010 plotting on HPdesignjet 500: DWG's not plotting, but no error?
    By Mauser in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2010, 06:43 pm
  2. cuiload Mishap
    By Bill Tillman in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jan 2010, 10:39 pm
  3. Plotting to PDF
    By nicnicman in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2009, 05:42 pm
  4. Plotting...
    By Luchini in forum AutoCAD General
    Last Post: 13th Oct 2005, 06:07 am
  5. Plotting.
    By Luchini in forum AutoCAD Beginners' Area
    Last Post: 12th Oct 2005, 07:26 pm
Tags for this Thread
