Rename pipes
anette_nilsson
I want to rename several structures but it seems not to work. In the Civil 2009 it worked, but in 2011 something goes wrong.
Menu: Pipes/Utilities/Rename nw parts
Select first: I do
Select next: f ex 10 structures away.
Then the dialogbox appears, but it says just 1 structure selected.
Ok: just the last selected structure will be renamed.
If I cancel the command, the first selected structure is still selected, but I cant unselect it by Esc.
I have to select it again and then it can be unselected by Esc.
It seems to do anything with the zoom-function. If I just select a few structures without zooming the renaming works, nearly every time, but not a larger amount of structures.
If I use the ribbon-menu, I can't select many structures.
I appreciate some help.
I have following specifications:
Windows 7 Enterprise
Proc: Intel Core(TM2) Duo CPU T9400 2,53 Ghz
RAM: 4,0 GB
System: 64-bit
NVIDIA Quadro FX 770M
DAC Type: Integrated RAMDAC
Available Graphics memory: 2269 MB
Video memory: 512 MB
Shared system memory: 1757 MB
Hope this is the information you want?
Don't know what images to send to you, it doesn't show anything on the screen, just one selected structure.
I am not sure if this could be your problem, but you are at the minimums for running Civil 3D 2011 on 64-bit.
What is PICKFIRST = ?
64-Bit AutoCAD Civil 3D 2011
Windows 7 Enterprise, Ultimate, Professional, or Home Premium (64-bit); Windows Vista Enterprise, Business, Ultimate (SP1 or SP2, 64-bit); or Windows XP Professional x64 Edition (SP2, 64-bit).
AMD Athlon 64, AMD Opteron, Intel® Xeon with Intel® EM64T support, Intel® Pentium® 4 with Intel EM64T support.
4 GB RAM minimum required, 8 GB RAM minimum recommended.
7 GB disk space with 2 GB free after installation.
1,280 x 1,024 true color video display adapter (true color) 128 MB or greater, Pixel Shader 3.0 or greater, Direct3D®-capable workstation-class graphics card. 1,600 x 1,200 or greater recommended. Multiple monitors are supported.
Microsoft® Internet Explorer® 7.0 or later.
DVD drive.
