Results 1 to 7 of 7
    Junior Member
    Movieangel's Computer Details
    Windows 7
    Alienware
    Architectural
    Movieangel's Discipline Details
    CAD Drafter/Designer
    Architectural
    AutoCAD 2012
    May 2011
    St. Louis
    14
    Default Help with Stud.LSP
    So I have tried to modify a batt insulation lsp originally created by David Sides to draw studs. You would think this would be easy because all I need are 45 degree lines, but I am having some trouble. I have gotten it to work for Horizontal walls and it is ok for vertical walls a bit glitchy but not horrible. Walls at an angle on the otherhand are horrible. Any advice?
    Code:
    STUD.LSP
    (setq
    xos (getvar "osmode"))
    (setvar "osmode" 0)
    (defun SSV
    (savelist)
     (mapcar
      '(lambda
    (sysvar)
       (list sysvar (getvar
    sysvar))
     savelist)
    (setq lista '("aunits"
    "auprec" "blipmode" "cmdecho"
                           "orthomode"))
    (defun
    RSV (savelist)
     (mapcar
      '(lambda
    (sysvar)
       (setvar (car sysvar)(cadr
    sysvar))
       (car
    sysvar)
     savelist)
    (defun
    HI ()
     (setq olderr *error*)
     (defun *error*
    (errstr)
      (print errstr)(princ)
      (setq lista (RSV
    lista))
      (setq *error*
    olderr)
     (setq lista (SSV
    lista))
     (setvar "aunits" 3)
     (setvar "auprec"
    8)
     (setvar "blipmode" 0)
     (setvar "cmdecho" 0)
     (setvar
    "orthomode" 0)
     (prompt "\nArchitectural studs. ")
     (prompt
    "\nBy Alison Baillargeon. July 12, 2011.
    (defun
    BYE ()
     (setq lista (RSV lista))
     (setq *error*
    olderr)(princ)
     (princ "\nProcessing complete.
    (defun
    c:STUD (/ A ANG1 ANG2 ANG3 LEN1 LEN2 PT1 PT2 PT3 PT4 PT5 THK1 THK2 THK3
    THK4)
     (HI)
     (setq PT1 (getpoint "\nEnter start point...
        PT2 (getpoint PT1 "\nEnter end point.
        THK1(getreal "\nEnter wall thickness.
        THK2(* THK1
    THK1)
        THK3(+ THK2
    THK2)
        THK4(sqrt
    THK3)
        LEN1(distance PT1
    PT2)
        LEN2(/ LEN1
    THK1)
        ANG1(angle PT1
    PT2)
        ANG2(+ ANG1
    0.7854)
        ANG3(+ ANG1
    5.4977)
        a 0
     (while (< a
    LEN2)
      (if (= a
    0)
        (setq PT3 (polar PT1
    ANG2 THK4)
         PT4 (polar PT3 ANG3
    THK4)
         PT5 (polar PT4 ANG2
    THK4)
           A
    0.5
        (command ".pline"
    PT1 "w" 0.0 0.0 PT3 PT4)
        (setq PT3
    PT5
         PT4 (polar PT3 ANG3
    THK4)
         PT5 (polar PT4 ANG2
    THK4))
        (command PT3
    PT4)
        (setq a (+ a
    2))
     (command
     (command ".break" "l" PT4 (polar PT4 ANG1
    THK4))
            (BYE)
     (setvar
    "osmode" xos)
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,888
    Please read the CODE POSTING GUIDELINES and edit your post.
    Junior Member
    Windows 7
    Alienware
    Architectural
    Architectural
    AutoCAD 2012
    May 2011
    St. Louis
    14
    I think I almost got it. My lisp works just as I would expect to create studs (after a whole day of trial and error as I am a newbie to Lisps) but it only works the first time after it has been loaded. In order for it to do what I expect after the first time, I have to type APPLOAD and reload it again. If I don't, it goes crazy. I am guessing it does not reset syetem variables and such, but I don't know how to fix it. Any help would be appreciated.
    Code:
    ;; STUD.LSP
    (setq
    (setvar "osmode" 0)
    (defun SSV
    (savelist)
     (mapcar
      '(lambda
    (sysvar)
    sysvar))
     savelist)
                           "orthomode"))
    (defun
    RSV (savelist)
     (mapcar
      '(lambda
    (sysvar)
    sysvar))
       (car
    sysvar)
     savelist)
    (defun
    HI ()
     (defun *error*
    (errstr)
      (setq lista (RSV
    lista))
      (setq *error*
    olderr)
     (setq lista (SSV
    lista))
     (setvar "aunits" 3)
     (setvar "auprec"
    8)
     (setvar
    "orthomode" 0)
     (prompt
    (defun
    BYE ()
     (setq *error*
    olderr)(princ)
    (defun
    THK4)
     (HI)
        THK2(* THK1
    THK1)
        THK3(+ THK2
    THK2)
        THK4(sqrt
    THK3)
        LEN1(distance PT1
    PT2)
        LEN2(/ LEN1
    THK1)
        ANG1(angle PT1
    PT2)
        ANG2(+ ANG1
    0.7854)
        ANG3(+ ANG1
    5.4977)
        a 0
     (while (< a
    LEN2)
      (if (= a
    0)
    ANG2 THK4)
         PT4 (polar PT3 ANG3
    THK4)
         PT5 (polar PT4 ANG2
    THK4)
           A
    0.5
        (command ".pline"
        (setq PT3
    PT5
         PT4 (polar PT3 ANG3
    THK4)
         PT5 (polar PT4 ANG2
    THK4))
        (command PT3
    PT4)
        (setq a (+ a
    2))
     (command
    THK4))
            (BYE)
     (setvar
    "osmode" xos)
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,418
    The following code uses a change in coordinate frame to make the calculation of the 'stud' points more succinct, however the drawback for this crafty shortcut lies in the fact that the trans function uses the arbitrary axis algorithm to define a coordinate frame from the supplied normal vector, and so this code will only work in UCS for which the UCS plane is parallel to the WCS plane.
    Code:
    (defun c:stud ( / p1 p2 n l s ) ;; © Lee Mac 2011
      (if
        (and
          (setq p1 (getpoint "\nSpecify Start Point: "))
          (setq p2 (getpoint "\nSpecify End Point: " p1))
          (progn (initget 6)
            (setq *w
              (cond
                  (getdist p1
                    (strcat "\nSpecify Wall Thickness"
                      (if *w (strcat " <" (rtos *w) ">: ") ": ")
                ( *w )
          (setq n (mapcar '- (trans p2 1 0) (trans p1 1 0))
                l (list (trans p1 1 n))
                s -1
          (repeat (fix (/ (distance p1 p2) *w))
            (setq l (cons (list (+ (* (setq s (- s)) *w) (caar l)) (cadar l) (+ *w (caddar l))) l))
          (entmakex
            (append
              (list
                (cons 0 "LWPOLYLINE")
                (cons 100 "AcDbEntity")
                (cons 100 "AcDbPolyline")
                (cons 90 (length l))
                (cons 70 0)
              (mapcar '(lambda ( p ) (cons 10 (trans p n 0))) l)
    The alternative approach, using polar may look something like this, and would work in all UCS/Views:
    Code:
    (defun c:stud ( / p1 p2 a n l s ) ;; © Lee Mac 2011
      (if
        (and
          (progn (initget 6)
            (setq *w
              (cond
                  (getdist p1
                ( *w )
          (setq n (trans '(0. 0. 1.) 1 0 t)
                a (angle p1 p2)
                l (list p1)
                s -1
            (setq l (cons (polar (polar (car l) a *w) (+ a (* (setq s (- s)) (/ pi 2.))) *w) l))
          (entmakex
            (append
              (list
                (cons 70 0)
                (cons 210 n)
              (mapcar '(lambda ( p ) (cons 10 (trans p 1 n))) l)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  5. #5
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,888
    I have deleted your other thread regarding the reloading of your LISP, because you have also asked in this thread and received a response.
  6. #6
    Junior Member
    Windows 7
    Alienware
    Architectural
    Architectural
    AutoCAD 2012
    May 2011
    St. Louis
    14
    Default Awesome
    Wow Lee Mac. Thanks so much for the code. I worked all day on mine, no kidding, over 8 hours, and it was still glitchy and yours is totally different but works perfectly. I wish I could understand lisps a bit better so this kind of stuff wouldn't take me forever, but I do really appreciate your help and maybe I can disect your code to figure out how it actually works to make future attempts a bit easier. Both work great. I will only be using this on floor plans so the UCS should not have any issues. Are there any advantages of one over the other? Thanks again. Really Really appreciate it.
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,418
    Quote Originally Posted by Movieangel View Post
    You're very welcome
    To be honest, its mostly practice coupled with a lot of reading - almost everything I know about LISP I have learnt from the Visual LISP IDE Help Documentation and these (and other) forums.
    The first code was demonstrating an alternative approach to the usual methods, I define a coordinate frame such that the points may be calculated at zero rotation, then transformed back to WCS when creating the LWPolyline. This allows for easier coordinate manipulation, but has some drawbacks. I was mainly experimenting with other ways to approach the problem, the second code is far more practical.
    The second code would be a better base for a beginner to learn from since it uses a more intuitive approach, calculating the points of the LWPolyline using the polar function.
    If you have any questions about any of the code I have posted I would be happy to provide some clarification.
    Lee
  1. Metal stud DB rotate issue
    By beardking in forum AutoCAD Drawing Management & Output
    Last Post: 7th Jun 2010, 06:51 pm
Tags for this Thread
