Check the help files on how to use the "pedit" command. It will convert a line into a polyline, and then you can join other segments, edit the width, etc.
Hi all, was just wondering how to convert a bunch of lines into one continuous polyline?
Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
PEDIT and use the Multiple option or there is MPEDIT in the Express Tools.
There's also a Join command.
breaking AutoCAD on a regular basis since 1991
There are two ways to do this:
1- I always find this procedure the easiest: use MPEDIT, select the lines, convert to polylines (YES), select JOIN and when it ask you to enter a fuzz distance just press ENTER and then press ESC to complete the process.
2- If you have an enclosed area that consist of lines, use the BOUNDARY (BO) command to convert those lines into polylines.
So I type in MPEDIT in the command line and I select the lines, what do I do after that? It keeps asking me all these different questions.
