Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    PEDIT is clunky .... PolyJoin is sleek
    Code:
    ;;---------------------=={ Polyline Join }==------------------;;
    ;;  Attempts to join all Lines, Arcs and LWPolylines in a     ;;
    ;;  selection.                                                ;;
    ;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
    (defun c:pj nil (c:PolyJoin))
    (defun c:PolyJoin ( / *error* _StartUndo _EndUndo vl ov ss )
      (vl-load-com)
      ;; © Lee Mac 2011
      (defun *error* ( msg )
        (if ov  (mapcar 'setvar vl ov))
        (if doc (_EndUndo doc))
            (princ (strcat "\n** Error: " msg " **"))
      (defun _StartUndo ( doc ) (_EndUndo doc)
        (vla-StartUndoMark doc)
      (defun _EndUndo ( doc )
        (if (= 8 (logand 8 (getvar 'UNDOCTL)))
          (vla-EndUndoMark doc)
      (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
      (_StartUndo doc)
      (setq vl '("CMDECHO" "PEDITACCEPT") ov (mapcar 'getvar vl))
      (mapcar 'setvar vl '(0 1))
      (if (setq ss (ssget "_:L" '((0 . "LINE,ARC,LWPOLYLINE"))))
        (command "_.pedit" "_M" ss "" "_J" "" "")
      (_EndUndo doc)
    Junior Member
    clepine's Computer Details
    Dell Precision T3400
    Two Dell monitors
    Civil 3D 2012
    Jul 2011
    Gillette, Wyoming USA
    16
    Typical autocad, theres usually more than one way to do something. The PE - JOIN process works as long as the lines you are joining together have the same beginning and end point, like if you were to draw several lines continouly. You can also connect multiple lines together that do not have the same beginning and end points connected by converting one line into a PLINE and using the FILLET - MULTIPLE command, select each end of two lines you want to join together, this will create the connected lines into a PLINE as long as the first one you select is a PLINE. You can also set a radius to the fillet, which is handy when you need to create a known radius that is tangent to two lines, like at road intersections.
  3. #13
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,596
    Quote Originally Posted by clepine View Post
    You can also connect multiple lines together that do not have the same beginning and end points connected by converting one line into a PLINE and using the FILLET - MULTIPLE command, select each end of two lines you want to join together, this will create the connected lines into a PLINE as long as the first one you select is a PLINE. ...
    This is no longer true, you don't need to convert a line to pline first, and you don't have to use fillet. If you have two lines say at 90 degrees to one another and not touching by 6 inches, start PE, Mulitple, pick, join, fuzzfactor >6, finished. They are now one pline.
    Last edited by rkent; 22nd Jul 2011 at 08:59 pm. Reason: clarified fuzzfactor value
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  4. #14
    Junior Member
    Two Dell monitors
    Civil 3D 2012
    Jul 2011
    16
    Quote Originally Posted by rkent View Post
    This is no longer true, you don't need to convert a line to pline first, and you don't have to use fillet. If you have two lines say at 90 degrees to one another and not touching by 6 inches, start PE, Mulitple, pick, join, fuzzfactor or 8, finished. They are now one pline.
    Cool, thats going to be especially helpful when the lines have different elevations.
  5. #15
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    I don't think so.... you can't join line segments that can't define a single plane.
  6. #16
    Junior Member Joseph Marquez's Avatar
    Joseph Marquez's Computer Details
    Windows 7 Home Premium
    Toshiba Satellite L505 Laptop
    Intel i7
    8.00 GB
    Intel® Graphics Media Accelerator 4500M
    1 TB
    20" HD LCD monitor
    AutoCAD 2011
    Jul 2011
    Houston, Texas
    18
    You answer Yes, enter, enter. Done.
    Simple and Quick. I LIKE IT! Thanks!
  7. #17
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Quote Originally Posted by Joseph Marquez View Post
  8. #18
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    292
  9. #19
    Forum Newbie
    AutoCAD 2013
    Sep 2013
    1
    This is what I was looking for thanks!
  10. #20
    Senior Member TheCADnoob's Avatar
    See details...
    TheCADnoob's Discipline Details
    Drafter
    See details below.
    Got a degree in rocket surgery that I cant use so I'm doing CAD work. I literally have my hands on all disciplines and am loving every minute of it, unfortunately by not specializing I believe I have found the Zen Noob. Jack of all master of none.
    AutoCAD 2013
    Mar 2015
    246
    Quote Originally Posted by Jack_O'neill View Post
    Check the help files on how to use the "pedit" command. It will convert a line into a polyline, and then you can join other segments, edit the width, etc.
    just what the dr ordered
  1. how to convert lines to polylines
    By gvgbabu in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jun 2011, 07:16 am
  2. remove double lines from drawing(lines,polylines,text)
    By cadamrao in forum AutoCAD Drawing Management & Output
    Last Post: 12th Apr 2010, 02:35 pm
  3. Convert polylines to 3Dpolylines?
    By EvilSi in forum AutoCAD General
    Last Post: 27th Apr 2009, 05:12 pm
  4. Convert Polylines into lines???
    By ramis in forum AutoCAD Beginners' Area
    Last Post: 21st Mar 2009, 10:16 pm
  5. Convert 3D Polylines to 2D
    By Matho in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Jul 2008, 04:11 am
Tags for this Thread
