Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2010
    Jul 2011
    2
    Default Draw > Point > Measure from origin?
    Hello, I'm currently trying to use the draw > point > measure tool to create a set of points around a polyline but I can't seem to get them to start at a point that I want. When I try and create the points they start from a random place. Any help would be greatly appreciated.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    Are you sure that it is a random place
    Measure starts from the endpoint nearest to where you picked the polyline, and the first point is not at the end, but at the measured distance from that end.
    Have another look, and if you are still mystified, post the drawing with only the polyline that is causing you problems.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    DIVIDE command might be an alternative to the MEASURE command as well. May want to give that a shot.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Forum Newbie
    AutoCAD 2010
    Jul 2011
    2
    I ended up getting it. I think the problem was that the polyline was a circuit, so I trimmed off a small section and added the points before joining the line back up. Thanks guys.
  1. Draw/Point/Measure/Inserrt Block query
    By Stanier in forum AutoCAD Beginners' Area
    Last Post: 10th Mar 2010, 06:41 pm
  2. Annotative block origin point
    By Alnaibii in forum AutoCAD Drawing Management & Output
    Last Post: 6th Mar 2009, 12:57 pm
  3. How to get the hatch origin point?
    By Johntosh in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Nov 2008, 05:07 pm
  4. Origin Point
    By FIFTHTEXAS in forum Autodesk Inventor
    Last Post: 5th Apr 2007, 07:09 pm
  5. how to move origin point ?
    By airs in forum AutoCAD Beginners' Area
    Last Post: 20th Nov 2006, 12:52 am
