Kremer Posted July 18, 2011 Share Posted July 18, 2011 I received a drawing this morning, and it's paperspace looks great. However when I tried to view the drawings in modelspace it was empty. All the layers are on, when I click into the viewport (in paperspace) I can draw a line on the same layer as the block and that will show up in modelspace, yet no block. Is this a feature of CAD, never experienced this before. P.s. The blocks are available to insert in modelspace , however I'm just curious as to why I can not see the blocks that quite clearly exist in modelspace already. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted July 18, 2011 Share Posted July 18, 2011 If you can see them in paper space but not in model space, is it possible that these blocks were inserted in paper space? Quote Link to comment Share on other sites More sharing options...
Kremer Posted July 18, 2011 Author Share Posted July 18, 2011 Well they're visible on paperspace inside of a viewport. I am able to select the blocks after entering into the viewport and the space tab switches to model. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 18, 2011 Share Posted July 18, 2011 When you were in model space did you do a Zoom > Extents? Quote Link to comment Share on other sites More sharing options...
Kremer Posted July 18, 2011 Author Share Posted July 18, 2011 Yes, I did this initially and after I drew a line over the block in modelspace via the viewport. Extents managed to find the line, yet no block. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted July 18, 2011 Share Posted July 18, 2011 Let's back up. In one place you say "block" and in another "blocks". Is it one or more than one? What is inside the block(s)? What type of layer is the block on? What type of layer is the viewport on? Did you try to re-create the viewport? Are you in the World UCS or some other UCS? Which UCS is the viewport using? Are there objects in model space that don't belong to the block(s)? Quote Link to comment Share on other sites More sharing options...
rkent Posted July 18, 2011 Share Posted July 18, 2011 In PS, make the viewport current, use View, save to a new name, go out to MS, use View, make that view name current. Quote Link to comment Share on other sites More sharing options...
Kremer Posted July 18, 2011 Author Share Posted July 18, 2011 Well there are three sheets, each sheet's contents (in modelspace) are a block. For example sheet P-170 has a block within it's viewport called P-170 and the entirety of the sheet is contained in that one block. Inside the blocks seem to just be lines on a layer which is on. I was attempting to clear out all relevant info on the project so I could post the file, when I discovered the viewports aren't visible. Yet when I click within the linework I enter modelspace. The file was too large to upload via this website so I went through yousendit: https://www.yousendit.com/download/cnJoSlI1Qk45RlkwTVE9PQ If you've got some spare time I'd appreciate if you guys could take a look. Many thanks Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted July 18, 2011 Share Posted July 18, 2011 Not sure why nothing shows in MS, but we are not dealing with core AutoCAD objects here. Command: [b]dblist[/b] Autodesk Inventor Object Autodesk Inventor Object Autodesk Inventor Object Autodesk Inventor Object Autodesk Inventor Object VIEWPORT Layer: "0" Space: Paper space Layout: P-100 COVER SHEET Invisible Visual Style: 2D Wireframe Handle = fb Status: On and Active Scale relative to Paper space: 0.0268xp Annotation Scale: 1'-0" = 1'-0" View lock is on center point, X=1'-4 13/16" Y=0'-10 1/2" Z=-34'-9 1/8" width 2'-3 13/16" height 1'-5 7/8" Quote Link to comment Share on other sites More sharing options...
Kremer Posted July 18, 2011 Author Share Posted July 18, 2011 Well I'm just going to assume something was lost in translation between Inventor and CAD. Thanks all ^^ Quote Link to comment Share on other sites More sharing options...
