Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2007
    Jul 2011
    4
    Default Getting dotted lines to show up from model space into viewport
    I am so frustrated as I cannot get my dashed lines in my model space to show up dashed in my viewport.
    I already tried MSLTSCALE = 1 in model space and PSLTSCALE = 1 and LTSCALE = 1 in paperspace.
    it did not work. Anyone have any ideas?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    Post the file.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,202
    In this situation I will override the linetype scale for a single line. I change it from 1 to .1 to .01 etc. If necessary I then change it from 1 to 10 to 100 etc. Eventually the pattern will appear. That will tell you what linetype scale you need to use for your drawing or for certain lines.
    breaking AutoCAD on a regular basis since 1991
    Forum Newbie
    AutoCAD 2007
    Jul 2011
    4
    i may be sounding like an idiot but how can i post the file?
  5. #5
    Forum Newbie
    AutoCAD 2007
    Jul 2011
    4
    RedondoBath.dwg
    i think i figured it out. how's that?
  6. #6
    Forum Newbie
    AutoCAD 2007
    Jul 2011
    4
    cyberangel- so do i click on the line in model space and start trying to adjust the scale like you said until is shows up in the viewport? is that what you mean?
  7. #7
    Super Member qball's Avatar
    Structural
    qball's Discipline Details
    Structural
    Structural / Architectural, Residential, Multi-family, Industrial, Wood frame, Steel, Masonry, Concrete, Tilt-up
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    Are you married to the Acadiso linetype? Because if you change a line to Dashed or Hidden or whatever it seems to work. I've never used the Acadiso stuff, so I don't know how they're different. Except apparently they don't work here.
    I don't have a catchy signature
  8. #8
    Full Member
    Kremer's Computer Details
    Xp
    AMD Phenom 9600 Quad-Core Processor, 2304 MHz
    3.326 Gig's (4Gig restricted by XP)
    NVIDIA GeForce 9800 GT (1024 MB)
    1.1 Tera
    19" HD
    MEP 2010
    Jul 2009
    San Diego
    91
    You can alter a single lines linetype scale by selecting the line and opening properties. It should be near the top of the window. This will only alter the selected objects.
  9. #9
    Senior Member bennyboy86's Avatar
    Structural
    bennyboy86's Discipline Details
    Structural Drafter
    Structural
    Revit 2015
    Jun 2011
    Sunshine Coast, Queensland, Australia
    117
    also if changing the linetype scale doesnt work, sometimes if you ahve copied work from other drawings you may have to reload the line type for that particular drawing. go to Linetype Manager and load the line type you want even if it there, it will ask you if you want to overide say YES.
  10. #10
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    Quote Originally Posted by qball View Post
    Good call!
    You need to use DASHED for the linetype not ACAD_ISO. ISO is usually for metric drawing not Imperial. You could use a LTSCALE of 0.0394 to make up the difference.
  1. Bring Paper Space object through Viewport into Model Space
    By karenreeves in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Nov 2011, 08:58 pm
  2. Replies: 6
    Last Post: 22nd Feb 2011, 07:34 pm
  3. How can I save a BLOCK to show up as dotted lines in a DWG file?
    By Spyder in forum AutoCAD Drawing Management & Output
    Last Post: 25th Sep 2009, 11:37 am
  4. I can't draw dotted lines in Model space.
    By tomr928 in forum AutoCAD Drawing Management & Output
    Last Post: 16th Dec 2005, 09:10 pm
  5. Show Dotted Lines In Paper Space
    By wellcad in forum AutoCAD General
    Last Post: 19th Nov 2004, 08:53 pm
Tags for this Thread
