+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
  1. #1
    Super Member irneb's Avatar
    Computer Details
    irneb's Computer Details
    Operating System:
    Win7 Pro 64bit
    Computer:
    Antec One Hundred
    Motherboard:
    ASUS P8P67-Pro P67
    CPU:
    Intel i7 2600 @ 3.4GHz
    RAM:
    16GB-1600MHz
    Graphics:
    GeForce GT 430 (1GB)
    Primary Storage:
    Seagate1TB SATA2 - 7200rpm
    Monitor:
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Discipline
    Architectural
    irneb's Discipline Details
    Occupation
    Architectural Technician and Programmer
    Discipline
    Architectural
    Using
    AutoCAD 2013
    Join Date
    Sep 2010
    Location
    Jo'burg SA
    Posts
    1,744
    Default Using Associative Dimensions
    There are various reasons for using associative dimensions. Previously the DimAssoc setting only had a 0 or 1 value. This meant all dims were either created as "exploded" or as one unit. Very few people would even consider using DimAssoc=0 as the dimensions are then next to useless. With DimAssoc=1 the dimensions could be stretched and the value would adjust accordingly.
    A few years back (about a decade or more) the DimAssoc=2 setting was introduced. When you change the setting in the Options dialog it actually toggles between DimAssoc=1 (off) and DimAssoc=2 (on).
    This "new" (read not too well known) setting causes some nifty feature in AutoCAD's dimensioning. Many would know this, but for those of us who don't here's a few examples of why you'd want it turned on:
    Not using Annotative Scales
    A lot of people have problems with using annotative scales. The only way to get around not using them would be to place all annotation on the paperspace, or creating several different textstyles and dimstyles - one for each scale to be displayed.
    With model space dimensions you needed to either do your dims through a viewport (and have the DimScale=0 so it adjusts accordingly) or have several DimStyles (each with a DimScale for the intended viewport scale). Also you'd need to place relevant dims on a layer to VPFreeze them in viewports where they shouldn't be shown.
    With paperspace dims you needed to have several DimStyles, each with a DimLFac to suit whatever viewport they will be drawn over.
    At least when placed on paper space you don't need to also have a set of layers so you can only show the relevant dim in its correct viewport.
    There's a further problem with paperspace dimensions: You can't now edit the linework and have the dim changed at the same time. E.g. you can't use the stretch command to lengthen a rectangle and its dimension in one instruction. But also you need to go and adjust the dimension on paperspace each time the model is changed. This becomes a shlep, to say the least!
    With DimAssoc=2 you have the best of both worlds. After you've edited the model, the dimension in paperspace adjusts to suit. But also, it now becomes unnecessary to fiddle with the DimLFac. Note this sample:
    • The red dimension is drawn inside the model of the viewport, the brown as a paperspace dim over the viewport (both drawn while DimAssoc=1).
    • The magenta dim is drawn inside the viewport and the maroon on top of the viewport, but both while DimAssoc=2.
    Notice the difference? There's no need to adjust the DimLFac to 50.0 in the sample, as would be the case for the brown dimension.
    Next post to show the "dynamicness" of associative dimensions.
    Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
    My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
  2. #2
    Computer Details
    Operating System:
    Win7 Pro 64bit
    Computer:
    Antec One Hundred
    Motherboard:
    ASUS P8P67-Pro P67
    CPU:
    RAM:
    16GB-1600MHz
    Graphics:
    Primary Storage:
    Monitor:
    Discipline
    Architectural
    Occupation
    Discipline
    Architectural
    Using
    AutoCAD 2013
    Join Date
    Sep 2010
    Location
    Jo'burg SA
    Posts
    1,744
    Default
    Automatic updating of dimensions
    When you edit the model space, it's easy to adjust the dimensions in one go. But also it's easy to see if a dimension isn't updated. It's not so nice when the dimension is drawn in paperspace though.
    Here is that same sample, but with the windows both stretched to be 1200 wide:
    Notice that it was "easy" to stretch the red dimension while changing the window itself. Not so for the brown though: here it needs to be edited on paperspace. Not too much of a hassle if it's only this one dim, but what happens if your drawing is more substantial that just this one instance? It could be very easy to miss a dimension ... not to mention, you're doing the same task twice!
    However, notice that the magenta AND the maroon dimensions have updated without needing to adjust them at all. In fact I didn't even include the magenta dimension while adjusting the window.
    ... next, we'll look at how these work on blocks. In particular dynamic blocks.
  3. #3
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO 64-bit
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    Pentium(R) i5 4570 @ 3.2GHz
    RAM:
    8 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    11,821
    Default
    Looking good so far.
    I may put this as a sticky in the beginners section, if no one objects.
  4. #4
    Computer Details
    Operating System:
    Win7 Pro 64bit
    Computer:
    Antec One Hundred
    Motherboard:
    ASUS P8P67-Pro P67
    CPU:
    RAM:
    16GB-1600MHz
    Graphics:
    Primary Storage:
    Monitor:
    Discipline
    Architectural
    Occupation
    Discipline
    Architectural
    Using
    AutoCAD 2013
    Join Date
    Sep 2010
    Location
    Jo'burg SA
    Posts
    1,744
    Default
    Dynamic Blocks - Adjusting their parameters
    While it's nice to be able to use things like stretch to adjust linework together with their dimensions, what about when you have to use another type of command? One where you cannot adjust the dimension in the same breath?
    A prime example is dynamic blocks. It's possible to change the size of a dynamic block, but only through using its grips / changing the value of its parameters.
    This shows the same drawing. But you'll notice the "windows" are actually dynamic blocks with height & width parameters. See how the "non-associative" dims (actually you could call them "half-associative" as they're not "exploded" ) didn't update when the window was changed to 1050 width?
    Well, if this doesn't show a good reason to use DimAssoc=2, then perhaps when you work with xrefs will ...
  5. #5
    Computer Details
    Operating System:
    Win7 Pro 64bit
    Computer:
    Antec One Hundred
    Motherboard:
    ASUS P8P67-Pro P67
    CPU:
    RAM:
    16GB-1600MHz
    Graphics:
    Primary Storage:
    Monitor:
    Discipline
    Architectural
    Occupation
    Discipline
    Architectural
    Using
    AutoCAD 2013
    Join Date
    Sep 2010
    Location
    Jo'burg SA
    Posts
    1,744
    Default
    Quote Originally Posted by SLW210 View Post
    Thanks! I'm still bussy ... might be a while
  6. #6
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,506
    Default
    Looks like we have the makings of a winner. Keep up the good work irneb.
  7. #7
    Computer Details
    Operating System:
    Win7 Pro 64bit
    Computer:
    Antec One Hundred
    Motherboard:
    ASUS P8P67-Pro P67
    CPU:
    RAM:
    16GB-1600MHz
    Graphics:
    Primary Storage:
    Monitor:
    Discipline
    Architectural
    Occupation
    Discipline
    Architectural
    Using
    AutoCAD 2013
    Join Date
    Sep 2010
    Location
    Jo'burg SA
    Posts
    1,744
    Default
    XRefs
    Here I've attached a new drawing into the previous one. Not a lot of new stuff, but it shows that these dimensions also work on external linework. See this sample:
    No real biggy! Let's open the other drawing and adjust the block over there:
    And back to the original, reload ... and see what happens.
    Oh-oh! Nothing's happened! Let's issue the DimRegen command as explained in the help:
    Ahhh! Now that's more like it!
    ... now, as always, there's a "catch". AutoCAD wouldn't be interesting without any hiccups now would it?
  8. #8
    Computer Details
    Operating System:
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    RAM:
    8 GB RAM
    Graphics:
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    11,821
    Default
    Moved to Beginner's and Stuck.
  9. #9
    Super Moderator Cad64's Avatar
    Computer Details
    Cad64's Computer Details
    Operating System:
    Windows 7 Profesional x64
    Computer:
    XI Computers
    Motherboard:
    Asus P8Z77-V Pro
    CPU:
    Intel Core I7 3770K 4.1 Ghz Quad Core 3rd Gen
    RAM:
    24GB DDR3 @ 1333MHz
    Graphics:
    Nvidia GeForce GTX 570 1280MB GDDR5
    Primary Storage:
    SATAII 500GB 7200 RPM
    Secondary Storage:
    Western Digital My Book Studio Edition II - 2TB capacity
    Monitor:
    HPf2105 21" LCD Widescreen & Cintiq 21ux
    Discipline
    Multi-disciplinary
    Cad64's Discipline Details
    Occupation
    Freelance Digital Artist
    Discipline
    Multi-disciplinary
    Details
    3D model building, texturing and rendering. Photoshop Color Graphics.
    Using
    AutoCAD 2014
    Join Date
    Feb 2006
    Location
    Southern California
    Posts
    10,176
    Default
    Shouldn't this be in the Tips and Tricks section?
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  10. #10
    Computer Details
    Operating System:
    Win7 Pro 64bit
    Computer:
    Antec One Hundred
    Motherboard:
    ASUS P8P67-Pro P67
    CPU:
    RAM:
    16GB-1600MHz
    Graphics:
    Primary Storage:
    Monitor:
    Discipline
    Architectural
    Occupation
    Discipline
    Architectural
    Using
    AutoCAD 2013
    Join Date
    Sep 2010
    Location
    Jo'burg SA
    Posts
    1,744
    Default
    Tips'n'Tricks, Beginners, who knows!
    Any how, to get on with it!
    Editing the block
    Seeing as this window is a slider, we'll add an arrow to indicate such. Let's do it in the original drawing first:
    BCose & Yes for save! Now let's go and adjust one of those original windows.
    Wonderful! It worked, the dims both updated from 1200 to 1350!
    Now let's go and push AutoCAD to its "limits"! Let's go do the same thing with the block inside the XRef:
    BClose, save ... and let's just (for the hell of it) change a window's size!
    , close, save, reload & finally DimRegen!
    Whoah! I broke it! Goes to show nothing in AutoCAD's "bullet" proof! From the help they do warn you that redefining a block will dis-associate these dimensions. Nowhere does it say a BEdit will not though! And no hope of being told it's going to break if you BEdit from inside the XRef!
    BTW, a similar thing occurs when you redefine the block through Design Center. Everything not part of a changeable portion of the dynamic block (or if it's not a dynamic block - which isn't very interesting) won't break when you use Design Center to redefine that block. But when you insert from file & redefine, or worse explode and recreate, the dimensions become normal DimAssoc=1 types.
    Of course there's the DimReAssociate command to go and fix these dimensions ... one at a time though! IMO, it's faster to just redo the dims!
Similar Threads
  1. Determine what associative dimensions are attached to.
    By manddarran in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Apr 2010, 09:43 pm
  2. Associative dimensions
    By DP-MWS in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Jan 2010, 02:34 pm
  3. Is it possible to create associative, PaperSpace dimensions using VBA
    By ginak in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jul 2009, 09:32 pm
  4. Need ideas... rotating associative dimensions
    By frostrap in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Feb 2008, 01:02 am
  5. associative dimensions in x-refs
    By michaeloureiro in forum AutoCAD Drawing Management & Output
    Last Post: 10th Jan 2008, 04:06 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
