Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Forum Newbie
    AutoCAD 2010
    Jul 2011
    6
    Well holy crap, the DVIEW thing worked! Thanks everyone! Great help
    And what's even better is that I also learned about the UCS command in the process of fixing the problem. Good stuff.
  2. #12
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,579
    Quote Originally Posted by emma0622 View Post
    This is a very simplistic example of the files I'm trying to fix. Many have hundreds of leaders and notes over much larger buildings. I'm thinking it is a viewport issue, but I still can't seem to figure out how to correct it.
    In this example you would go into Modelspace and type
    UCS, enter, Z, enter, 270, enter, Plan,enter, Current, enter
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  3. #13
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Yeah, they've rotated the UCS in your paperspace viewport to account for the rotated model. There are several ways to "fix" it, but the simplest is just change the Modelspace UCS and then set PLAN to [C]urrent so the Modelspace UCS and the Paperspace Viewport match.
    like this http://www.screencast.com/t/CAGgY55yfU
    If you want to always work on the WCS (world coordinate system) rotate everything in modelspace, then rotate the UCS for your Paperspace viewport.
    The downfall of only using DVIEW is that it only twists your view, so X and Y aren't "left" and "up" relative to your screen.
  4. #14
    Forum Newbie
    AutoCAD 2010
    Jul 2011
    6
    Sorry, Daniel. I'll change my method next time I need to upload a file. Thanks for letting me know, and for your help. Much appreciated.
  5. #15
    Super Member DANIEL's Avatar
    Mechanical
    DANIEL's Discipline Details
    Industrial
    Mechanical
    AutoCAD 2013
    May 2005
    Arlington Texas
    1,005
    no problem, I'm just glad you got your issue solved
    If you would like to help my 2 year old niece Alaina in her battle against Leukemia you can donate blood at any Carter Blood Care and put SPON050875 on the donor form. Thank you so much for any contributions in this matter that you can make.
    Luminous beings are we, not this crude matter.
  6. #16
    Forum Newbie
    AutoCAD 2010
    Jul 2011
    6
    For future reference on this issue, the UCS method put forth by nestly does work, but it's acutally faster (at least for my particular problem) to use the DVIEW command suggested by Kremer.
    That video posted by nestly is a very clear way to learn more about the UCS function.
  7. #17
    Full Member
    Kremer's Computer Details
    Xp
    AMD Phenom 9600 Quad-Core Processor, 2304 MHz
    3.326 Gig's (4Gig restricted by XP)
    NVIDIA GeForce 9800 GT (1024 MB)
    1.1 Tera
    19" HD
    MEP 2010
    Jul 2009
    San Diego
    91
    To correct your X & Y after using DVIEW:
    UCS -> View (v)
    Should do the trick
  1. How to select the blocks only in current space (either model or paper space)
    By muthu123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2011, 08:34 pm
  2. 2011 AutoCAD - Setting my LTSCALE in Paper Space as the same it is in Model Space
    By Rage221677 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Dec 2010, 07:31 pm
  3. Lisp- Copy Txt Form Model Space 2 Paper Space
    By T704 in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jun 2010, 04:19 pm
  4. AcadPViewport2 - Deleting items in model space that aren't seen inside paper space
    By lovemy65stang in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2009, 05:26 am
  5. Replies: 0
    Last Post: 22nd Jan 2007, 10:20 pm
Tags for this Thread
