Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
Thread: Invisible lines
    Full Member
    AutoCAD 2009
    Feb 2008
    Bradford, West Yorkshire, England
    33
    Default Invisible lines
    Hi all,
    I've received a drawing from a customer, which is a room layout in 2D. There are loads of lines which are invisible, but you can see they are there by selecting them. I've moved all lines to a visible layer, they are all the same colour, thickness, linetype, etc (I've checked this by drawing a new line, and matching properties with it), but the lines refuse to remain visible. Has anyone found this before, and know of the reason for the invisible lines?
    Thank you
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Could they be behind a wipeout or solid hatch.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,870
    You could post an image or everyone could continue guessing.
    Did you check layer transparency?
    Full Member
    AutoCAD 2009
    Feb 2008
    33
    SLW210 - do you need a beer? This is the second time you've replied to me in a less-than-friendly way. Remember, this is the "AutoCAD Beginner's" forum, hence I'm new to this. Anyway, how do I post a picture of an invisible line? The first image would show a black screen, the second would show a selected straight line?!? I'm sure you don't need to be Stephen Hawking to guess what it would look like....
    Anyway, I've found a wipeout linetype that I can't purge. There are also a load of blocks which I can't purge. I'm sure this is something to do with XREF's, which I don't understand at all, they seem like a waste of time to me...
    Please help! (not with "everyone can continue guessing" remarks please)
  5. #5
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Can you post the drawing here?
  6. #6
    Full Member
    AutoCAD 2009
    Feb 2008
    33
    Hi Nestly,
    I can't see a way of attaching a DWG - only a link or image. The drawing is 5Mb anyway, and I've discovered that it has been created using something other than AutoCAD, as it said as I opened the drawing in AutoCAD. There are approx 40 blocks which I can't select or purge (I've tried all I know, like qselect to pick them). There is a wipeout linetype which I also can't purge, as it's "used in the drawing". I'm resorting to plotting the drawing as a PDF, and converting it back to DWG. Messy, but works.
  7. #7
    Senior Member Arizona's Avatar
    Arizona's Computer Details
    XP Prp
    Dell Precision 370
    2 Gig
    NVIDIA GeForce 7800 GTX
    2 17" Dells
    Land Desktop 2006
    Dec 2002
    South Jersey, USA
    187
    Dude, XRef's are simply another drwaing shown in the background. A Fabulous tool.
    When you do select one of the ******s, in the properties box:
    - what layer is it on?
    - what color is it?
    - what linetype is it?
    - what are it's Z values?
    What happens if you put it on a different layer?
    Also - You could be in Perspective View. Sometimes that makes a mess.
    Try typing PLAN, then hit enter twice.
    There are may things that could do this.
    To attach:
    Click REPLY (not the quick reply but the full one)
    Click MANAGE ATTACHMANTS
  8. #8
    Full Member
    AutoCAD 2009
    Feb 2008
    33
    Ok, you talked me into posting images....
    There's a "before select" and "after select"
  9. #9
    Full Member
    AutoCAD 2009
    Feb 2008
    33
    Of course, the images are the wrong way round - the before select is the lower image, the after select is the upper one.
  10. #10
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,870
    Quote Originally Posted by ServaCleanCAD View Post
    How was that less than friendly? I will not be helping you.
  1. Make lines invisible
    By dreamer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Jan 2011, 05:53 pm
  2. Invisible Attributes
    By grain in forum AutoCAD General
    Last Post: 25th Nov 2008, 02:30 pm
  3. Replies: 10
    Last Post: 30th Dec 2005, 03:54 pm
  4. Little help needed with visible/invisible lines
    By jay in forum AutoCAD Beginners' Area
    Last Post: 19th Dec 2005, 10:42 pm
  5. 3D surfaces wiremesh lines invisible
    By ggtoutounji in forum AutoCAD 3D Modelling & Rendering
    Last Post: 28th Feb 2005, 08:51 pm
