Results 1 to 1 of 1
    Junior Member
    AutoCAD 2012
    Jul 2011
    19
    Default Break Intersecting Lines with Selection Set
    Code:
    (defun c:BIL (/ *error* pt1 ent ang b1 b2 useros usercmd)
    (vl-load-com)
    (defun *error* (msg)
    (if (not
    (member msg '("console break" "Function cancelled" "quit / exit abort" "" nil)))
    ) ; if
    (and usercmd (setvar "CMDECHO" usercmd))
    (and useros (setvar "osmode" useros))
    ) ; end error function
    (setq useros (getvar "osmode"))
    (setq usercmd (getvar "CMDECHO"))
    (and
    (setq ent (car (entsel "\n Select line to break ")))
    (setvar "osmode" 32)
    (setq pt1 (getpoint "\n Select Intersection of Lines "))
    (setq ang (angle '(0 0)
    (vlax-curve-getFirstDeriv ent
    (vlax-curve-getParamAtPoint ent pt1)))
    (setq b1 (polar pt1 ang 0.0625))
    (setq b2 (polar pt1 (+ ang pi) 0.0625))
    (setvar "osmode" 0)
    (command "_.break" ent b1 b2 "")
    (*error* "")
    ){code}
    Is there a way to add a selection set to this lsp.? It works great but it would be a lot faster if I could do a selection set. I also want to still be able to modify the distances need be, because this one is set to 1/16" now but I might need to change that with other applications. If someone could help that would be great, Thanks.
  1. Break lines around blocks with selection
    By ibanez_222 in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Oct 2012, 01:07 am
  2. Intersecting Objects Lines/Arcs/Mlines
    By harrison-matt in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jun 2011, 03:08 am
  3. Intersecting lines
    By Tyke in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jan 2010, 09:49 am
  4. Intersecting lines
    By MR MAN in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Nov 2009, 02:04 am
  5. Break 2 Intersecting Lines
    By wherestheanykey in forum AutoCAD Drawing Management & Output
    Last Post: 16th Apr 2007, 11:32 pm
