Results 1 to 7 of 7
    Junior Member
    AutoCAD 2006
    Feb 2006
    18
    Default .pdf to .dwg conversion
    superb helping commmunity!
    can anyone pls suggest a FREE download link to convert .pdf files into .dwg & vice-versa?
    any help in this regard would b greatly appreciated.
    ty
    Rainbow
    Full Member
    not specified
    Feb 2006
    Finland
    63
    There is a pdf-printer inside AutoCAD that makes pdf-files from dwg's. (Is it automatically on every AutoCAD?)
    But pdf's to dwg's. I don't think that's possible. Please someone correct me if I'm wrong.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    Try this:
    http://anydwg.com/pdf-to-dwg.html
    The company claims to have a PDF to DWG (DXF) conversion program that does not require AutoCAD.
    They also have a whole host of other conversion programs as well. See the listing to the far right of the opening web page.
    Full Member
    not specified
    Feb 2006
    Finland
    63
    Yeap, that seems to do the trick.
    But it's not free after the trial period...
  5. #5
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Also not free: open the PDF in Corel Draw and export as DXF or even as DWG. Not free and not cheap
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  6. #6
    Senior Member Vince0115's Avatar
    Vince0115's Computer Details
    XP Media
    Dell something
    21" HP P1110 CRT
    not applicable
    Feb 2005
    Chicago
    150
    Default pdf
    Here's a free one: www.cutepdf.com
    but I don't know if it goes back from pdf to dwg.
    Good Luck
    Vince
  7. #7
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,925
    A real cludge of a way, but if all else fails
    Well..... it's free...
    Setup A Large Format Plotter
    Add a monochrome HP plotter
    HP 600 Drivers come with Windows now
    I use the 36" roll paper and E size
    It needs to be an older HP that doesn't support PCL
    Configure it to plot to a file only
    Plot The PDF File
    Plot the PDF file to the HP plotter
    Plot to a predefined scale if possible.
    Convert The HPGL2 PLT File to DXF
    There are free converters than can do this conversion.
    Govert's Tools has 1
    http://www.output.tmfweb.nl
    DXFIN The New File
    Use ACAD's DXFIN in a new DWG
    Do not use a template DWT
    Scale The New DWG
    Scale everything in the dwg the inverse of the plotting scale
    If there was no way to plot to scale, hopefully
    there is 1 dimension somewhere in the drawing that is
    known and can be compared to the the DXF data.
    Trace The Line
    You can use endpoint snap to trace the lines in the new dwg.
    Erase all of the unused PDF junk
    Draw Backs
    Very Very Large Drawings
    Scaling can be tedious
    Scales must be checked and double checked
    Tracing can be very tedious
    -David
    R12 (Dos) - A2K
