I'm pretty sure that Inventor nor any Autocad product has any allowable interoperability for this as Solidworks is AutoDesk's main competition.. If you cant import the file directly using Inventors import system, then the best thing you can do is either export it into a .PDF file or a generic DWF or DWT if this is possible in solidworks, then import it this way...
Hope this helps
QE
