+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Full Member
    Using
    AutoCAD 2011
    Join Date
    May 2011
    Location
    Idaho
    Posts
    35
    Question Scale of Cells When Placing in drawings
    In some of my drawings when I place cells 1 to 1 they dont come in 1 to 1 even though in my Place Active Cell box it is set to 1.00000?
    For example I am placing a component that measures .1457ft across in the .cel file. when i place it in a few of my drawings it places in at .0182ft. In other drawings it comes in correctly at .1457ft. Is there a setting somewhere that controls that? Or if i placed a cell in the passed that came in at .0182ft and I changed the scale but it has the same name, would that effect how it come in? I know it does in AutoCAD you have to purge out the old block.
  2. #2
    Full Member envisioncad's Avatar
    Computer Details
    envisioncad's Computer Details
    Operating System:
    Windows XP Pro and above
    Computer:
    Dell Laptop Precision
    Using
    Civil 3D 2013
    Join Date
    Jul 2010
    Location
    Madison, WI, United States
    Posts
    54
    Default
    Fastdraft, there is a check box in the Tool Settings window for "True Scale" (you may have to expand the dialog with the little black down arrow). Check "True Scale" OFF and that should take care of it. If you still have trouble let me know.
    The reason that it may work in some drawing and not others is that the tool settings are stored in each file so it maybe already toggled off in some the drawings.
    HTH,
    Bob Mecham
  3. #3
    Full Member
    Using
    AutoCAD 2011
    Join Date
    May 2011
    Location
    Idaho
    Posts
    35
    Default
    Where is Tool Settings? how do i get into it? i cant find a Ture Scale selection? I am using microstation V8
  4. #4
    Computer Details
    Operating System:
    Computer:
    Using
    Civil 3D 2013
    Join Date
    Jul 2010
    Location
    Posts
    54
    Default
    Fastdraft, the tool settings window should appear when you select the place cell icon. Here is a screen capture it may look different depending on what version of v8 you are using. I am running V8i (SELECTseries 2).
  5. #5
    Full Member
    Using
    AutoCAD 2011
    Join Date
    May 2011
    Location
    Idaho
    Posts
    35
    Default
    Ah Ic sweet! thanks!
Similar Threads
  1. help printing drawings to scale
    By helpmeplease in forum AutoCAD Beginners' Area
    Last Post: 15th Mar 2010, 02:53 am
  2. Issues with the scale of my drawings...
    By Reecox in forum AutoCAD Beginners' Area
    Last Post: 9th Mar 2009, 01:19 am
  3. Placing drawings into a word document
    By shoehne in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2009, 02:31 pm
  4. Plotting old drawings to scale
    By swojcik in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Oct 2008, 11:11 am
  5. Knowing what scale your drawings are at.
    By MarkCalvert in forum AutoCAD Drawing Management & Output
    Last Post: 10th Dec 2007, 01:58 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
