Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Super Member Bill Tillman's Avatar
    AutoCAD 2013
    Oct 2008
    Miami, FL
    874
    Default Problem with PEDIT to Extrude Shape
    I have a picket for a fence we're building and the manufacturer supplied me with a CAD file for it. It's an odd shape ornamental aluminum part and I'd like to PEDIT it so I can extrude it and make it part of a 3D model. There are some splines as well as lines in this shape and for some reason I cannot get the PEDIT command to close it. Any advice would be appreciated.
    OK, I tested this with the JOIN command and got what I was after. Learn something new every day.
    It's deja vu, all over again.
    Forum Deity Jack_O'neill's Avatar
    Jack_O'neill's Computer Details
    xp
    Architectural
    Jack_O'neill's Discipline Details
    Architectural
    The bulk of my business is commercial curtainwall, site plans and floor plans. I do occasionally get a bit of tool and die, and the odd house now and again.
    AutoCAD 2010
    Sep 2008
    lost in the Arkansas wilderness
    2,146
    Turn the splines into polylines one at a time, then join them.
    Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,969
    Pedit does not work with Spline curves. However, if you Flatten the Spline, it becomes a polyline.
    xp
    Architectural
    Architectural
    AutoCAD 2010
    Sep 2008
    2,146
    Pedit will convert a spline to a polyline, but you have to enter a precision. Thats why I said do them one at a time. Looks like this after it's extruded:
    Here is the command line sequence:
    Command: pedit
    Select polyline or [Multiple]:
    Object selected is not a polyline
    Do you want to turn it into one? <Y> y
    Specify a precision <10>:
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,969
    Isn't progress marvellous
    You used to be able to do them all together, and now you can do them one at a time.
  6. #6
    xp
    Architectural
    Architectural
    AutoCAD 2010
    Sep 2008
    2,146
    What it won't do is convert a spline during the "join" option. You have to convert them one at a time first, then it will join them. When I did the one on the inside (or, to the right in Bill's drawing) then joined it, it found 77 segments!
  7. #7
    Senior Member rvpas's Avatar
    rvpas's Computer Details
    xp pro
    laptop HP Compaq nx9420 - workstation hp
    Architectural
    rvpas's Discipline Details
    building CAD designer and AUTOCAD ATC instructor free lance
    Architectural
    Help to design building with architect work with REVIT and AUTOCAD during the step of conception, follow the contruction site, building survey. ATC Instructor with trainng center 2d 3d AUTOCAD and REVIT
    AutoCAD 2012
    Apr 2010
    Savigny sur orge - south of paris
    172
    You can use Presspull too
    Home tab/Modeling panel/PressPull
    Click inside your boundary area and give height
    Bye
    Pascal
  8. #8
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Quote Originally Posted by Bill Tillman View Post
    As indicated - presspull does not have the limitation of requiring a closed polyline.
    You can have any combination of lines, polylines, splines, circles and arcs form your boundary with presspull.
    No need to convert splines to polylines, no reason to PE Join, no need to flatten.
    Since release 2007 you should almost always be using presspull rather than extrude.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  9. #9
    xp
    Architectural
    Architectural
    AutoCAD 2010
    Sep 2008
    2,146
    Quote Originally Posted by JD Mather View Post
    I didn't even know presspull existed till I got 2010 and still rarely use it. Just can't seem to remember that it's there for some reason.
  10. #10
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Quote Originally Posted by Jack_O'neill View Post
    http://home.pct.edu/~jmather/AU2007/...P%20Mather.pdf
    see page 5
    and Tutorial 1 in my signature.
  1. How do I extrude a isometric shape
    By peterg in forum AutoCAD Beginners' Area
    Last Post: 28th Feb 2010, 06:42 pm
  2. Creating a complex shape to extrude?
    By bbudding in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Nov 2009, 09:36 am
  3. Extrude to Convex Shape
    By wgross in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Oct 2008, 03:40 am
  4. How do i extrude an arc combined with line (D shape)
    By fahad in forum AutoCAD General
    Last Post: 21st Nov 2005, 01:29 pm
  5. Can't extrude my first shape.
    By CptanPanic in forum Autodesk Inventor
    Last Post: 26th Aug 2005, 10:24 pm
