Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Full Member baker's Avatar
    Civil 3D 2012
    May 2011
    57
    Default All blocks to be set to ByLayer (color and linetype)
    I searched and did not really find the results i was looking for.
    I am looking for a Lisp that when called, will change every block in the DWG to ByLayer color and line type.
    I have one i found recently that works, but you have to select each block.
    this is the Lisp i found..
    Code:
        ;   File Name: FIXBLOCK.LSP
        ;   Description: Puts all of a blocks sub-entities on layer 0 with color and
        ;					  linetype set to BYBLOCK. The block, itself, will remain on
        ;					  its' original layer.
    (defun d_FixBlock (/             eBlockSel ; Block selection
                       lInsertData ; Entity data
                       sBlockName ; Block name
                       lBlockData ; Entity data
                       eSubEntity ; Sub-entity name
                       lSubData ; Sub-entity data
                       iCount ; Counter
      ;; Redefine error handler
      (setq
        d_#error *error*
        *error*  d_FB_Error
      ) ;_ end setq
      ;; Set up environment
      (setq #SYSVARS (#SaveSysVars (list "cmdecho")))
      (setvar "cmdecho" 0)
      (command "._undo" "_group")
      ;; Get block from user and make sure it's an INSERT type
      (if (setq eBlockSel (entsel "\nSelect block to change :"))
          (if (setq lInsertData (entget (car eBlockSel)))
            (if (= (cdr (assoc 0 lInsertData)) "INSERT")
              (setq sBlockName (cdr (assoc 2 lInsertData)))
                (alert "Entity selected is not a block!")
                (exit)
              ) ;_ end progn
            ) ;_ end if
              (alert "Invalid Block Selection!")
              (exit)
            ) ;_ end progn
          ) ;_ end if
          ;; Get block info from the block table
          (setq
            lBlockData (tblsearch "BLOCK" sBlockName)
            eSubEntity (cdr (assoc -2 lBlockData))
          ) ;_ end setq
          ;; Make sure block is not an Xref
          (if (not (assoc 1 lBlockData))
              (princ "\nProcessing block: ")
              (princ sBlockName)
              (princ "\nUpdating blocks sub-entities. . .")
              ;; Parse through all of the blocks sub-entities
              (while eSubEntity
                (princ " .")
                (setq lSubData (entget eSubEntity))
                ;; Update layer property
                (if (assoc 8 lSubData)
                    (setq lSubData
                           (subst
                             (cons 8 "0")
                             (assoc 8 lSubData)
                             lSubData
                           ) ;_ end subst
                    ) ;_ end setq
                    (entmod lSubData)
                  ) ;_ end progn
                ) ;_ end if
                ;; Update the linetype property
                (if (assoc 6 lSubData)
                    (setq lSubData
                           (subst
                             (cons 6 "BYBLOCK")
                             (assoc 6 lSubData)
                             lSubData
                           ) ;_ end subst
                    ) ;_ end setq
                    (entmod lSubData)
                  ) ;_ end progn
                  (entmod (append lSubData (list (cons 6 "BYBLOCK"))))
                ) ;_ end if
                ;; Update the color property
                (if (assoc 62 lSubData)
                    (setq lSubData
                           (subst
                             (cons 62 0)
                             (assoc 62 lSubData)
                             lSubData
                           ) ;_ end subst
                    ) ;_ end setq
                    (entmod lSubData)
                  ) ;_ end progn
                  (entmod (append lSubData (list (cons 62 0))))
                ) ;_ end if
                (setq eSubEntity (entnext eSubEntity))
        ; get next sub entity
              ) ; end while
              ;; Update attributes
              (idc_FB_UpdAttribs)
            ) ; end progn
            (alert "XREF selected. Not updated!")
          ) ; end if
        ) ; end progn
        (alert "Nothing selected.")
      ) ; end if
    ;;; Pop error stack and reset environment
      (idc_RestoreSysVars)
      (princ "\nDone!")
      (setq *error* d_#error)
    )   ; end defun
        ; Function to update block attributes
    (defun idc_FB_UpdAttribs ()
      ;; Update any attribute definitions
      (setq iCount 0)
      (princ "\nUpdating attributes. . .")
      (if (setq ssInserts (ssget "x"
                                 (list (cons 0 "INSERT")
                                       (cons 66 1)
                                       (cons 2 sBlockName)
                                 ) ;_ end list
                          ) ;_ end ssget
          ) ;_ end setq
        (repeat (sslength ssInserts)
          (setq eBlockName (ssname ssInserts iCount))
          (if (setq eSubEntity (entnext eBlockName))
            (setq
              eSubType (cdr (assoc 0 lSubData))
            ) ;_ end setq
          ) ;_ end if
          (while (or (= eSubType "ATTRIB") (= eSubType "SEQEND"))
                (setq lSubData
                       (subst
                         (cons 8 "0")
                         (assoc 8 lSubData)
                         lSubData
                       ) ;_ end subst
                ) ;_ end setq
                (entmod lSubData)
              ) ;_ end progn
            ) ;_ end if
                (setq lSubData
                       (subst
                         (cons 6 "BYBLOCK")
                         (assoc 6 lSubData)
                         lSubData
                       ) ;_ end subst
                ) ;_ end setq
                (entmod lSubData)
              ) ;_ end progn
            ) ;_ end if
                (setq lSubData
                       (subst
                         (cons 62 0)
                         (assoc 62 lSubData)
                         lSubData
                       ) ;_ end subst
                ) ;_ end setq
                (entmod lSubData)
              ) ;_ end progn
            ) ;_ end if
            (if (setq eSubEntity (entnext eSubEntity))
              (setq
              ) ;_ end setq
              (setq eSubType nil)
            ) ;_ end if
          ) ; end while
          (setq iCount (1+ iCount))
        ) ; end repeat
      ) ; end if
      (command "regen")
    )   ; end defun
        ; Function to save a list of system variables
    (defun #SaveSysVars (lVarList / sSystemVar)
      (mapcar
        '(lambda (sSystemVar)
           (setq lSystemVars
                  (append lSystemVars
                          (list (list sSystemVar (getvar sSystemVar)))
                  ) ;_ end append
           ) ;_ end setq
         ) ;_ end lambda
        lVarList
      ) ;_ end mapcar
      lSystemVars
    ) ;_ end defun
        ; Function to restore a list of system variables
    (defun idc_RestoreSysVars ()
      (mapcar
           (setvar (car sSystemVar) (cadr sSystemVar))
         ) ;_ end lambda
        #SYSVARS
      ) ;_ end mapcar
    ) ;_ end defun
        ; Error Handler
    (defun d_FB_Error (msg)
      (princ "\nError occurred in the Fix Block routine...")
      (princ "\nError: ")
      (princ msg)
      (if *error*
        (*error* msg)
      ) ;_ end if
      (command)
      (if (/= msg "quit / exit abort")
          (command "._undo" "_end")
          (command "._u")
        ) ;_ end progn
      ) ;_ end if
    ) ;_ end defun
    (defun FB () (d_FixBlock))
    (fb)
    also, i cannot get this lisp to work without apploading each time i need it.
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,945
    Why not just use the SETBYLAYER command?
    "Potential has a shelf life." - Margaret Atwood
    Civil 3D 2012
    May 2011
    57
    Quote Originally Posted by RenderMan View Post
    because i forgot about that command.. lol.
    Civil 3D 2011
    Nov 2009
    3,945
    Quote Originally Posted by baker View Post
    lmfao
    ... Happy to help!
  5. #5
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,627
    Me too , every time Renderman reminds me of it by his precious words and I keep on forgetting it .
    My routine is ready to delivery but this command hold my energy LOL....
    - When aim is being settled in my mind , I have to reach it and get it in hand whatever it costs and wherever it is and will never give up . Tharwat said
  6. #6
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,926
    I honestly don't know much about setbyblock, but this should give a bit of flexibility as well
    Code:
    (defun c:blk2def (/ bl tdef fe fd)
    ;;;GROUP LIST Group_Number Sysvar_Name New_Value
      (setq bl '(( 8 "CLAYER"      "0")
                 ( 6 "CELTYPE"     "BYLAYER")
                 (39 "THICKNESS"    0.0)
                 (48 "CELTSCALE"    1)
                 (62 "CECOLOR"      256)))
      (while (setq tdef (tblnext "BLOCK" (not tdef)))
             (setq fe (cdr (assoc -2 tdef)))
             (princ (strcat "\n" (cdr (assoc 2 tdef))))
             (entmake tdef)
             (while fe
               (setq fd (entget fe))
               (foreach g bl
                  (cond ((not (getvar (nth 1 g))))
                        ((assoc (nth 0 g) fd)
                         (setq fd (subst (cons (nth 0 g) (nth 2 g))
                                         (assoc (nth 0 g) fd) fd)))
                        (T
                         (setq fd (append fd (list (cons (nth 0 g) (nth 2 g))))))))
               (entmake fd)
               (setq fe (entnext fe)))
             (entmake (list (cons 0 "ENDBLK")(cons 8 "0"))))
      (command "_.REGENALL")
      (prin1))
    You can manipulate the list bl to your needs.
    • SNVALID Layer Name
    • Linetypes must exist prior to calling this for it work properly.
    • Colors 0-256
    It does not address existing ATTRIButes.
    -David
    R12 (Dos) - A2K
  7. #7
    Civil 3D 2012
    May 2011
    57
    ahhhh... now i remember.. i want the linework in the blocks to move to layer 0 as well as bylayer for everything else..
  8. #8
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,718
    Give this a try:
    Code:
    (defun c:test ( / acdoc )
        ;; All block objects to Layer "0", Color/Linetype ByLayer
        ;; Lee Mac 2011  -  www.lee-mac.com
        (vlax-for block
            (vla-get-blocks
                (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
            (if
                (and
                    (eq :vlax-false (vla-get-islayout block))
                    (eq :vlax-false (vla-get-isxref block))
                (vlax-for object block
                    (mapcar
                        (function
                            (lambda ( property value )
                                (vl-catch-all-apply 'vlax-put-property (list object property value))
                       '(layer color linetype)
                        (list "0" acbylayer "BYLAYER")
        (vla-regen acdoc acallviewports)
    (vl-load-com) (princ)
    Lee Mac Programming
    Just another Swamper
  9. #9
    Civil 3D 2012
    May 2011
    57
    Lee,
    you are going to kill me. That is great and i will use that lisp.. Is there a way to have another lisp (or the option in this lisp) to put the block's objects to the layer the block is inserted to?
  10. #10
    Civil 3D 2011
    Nov 2009
    3,945
    Lee,
    Consider replacing this line:
    Code:
    ... with this one:
    Code:
    (list (vla-get-layer object) acbylayer "BYLAYER")
  1. Default color of [ Bylayer ]
    By basiony in forum AutoCAD Beginners' Area
    Last Post: 23rd Nov 2010, 08:41 am
  2. Lisp to change linetype in block bylayer
    By mxpxh2o in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jun 2010, 04:13 pm
  3. color bylayer
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Oct 2009, 02:07 pm
  4. from bylayer to by color
    By russell84 in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jul 2008, 02:59 pm
  5. set color & lintype back to bylayer after drawing a line
    By raj banerjee in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Sep 2007, 10:16 am
