Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    Forum Newbie
    Architecture 2011
    Jul 2012
    3
    I recently stumbled upon your lisp routine and was wondering if it can be altered to select all instances of a specific block within the drawing?
    Thanks!
  2. #12
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Not sure what routine you were referring, but the code below will create a selection set with all block instances (presuming is not about a dynamic block):
    Code:
    (ssget "_X" '((0 . "INSERT") (2 . "NameOfBlock")))
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  3. #13
    Forum Newbie
    Architecture 2011
    Jul 2012
    3
    My apologies. The lisp in question is:
    Code:
    (sssetfirst nil (ssget "_x" '((0 . "VIEWPORT") (8 . "<LayerName>"))))
    and this request is indeed regarding a dynamic block. I'd like to be able to select all the dynamic blocks in the drawing and modify their visibility state.
    Thanks again!
  4. #14
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    In this case then please check the documentation recommended by Lee Mac in this post.
    Also, please edit your post and add the mandatory code tags. Thank you.
    Regards,
    Mircea
  5. #15
    Forum Newbie
    Architecture 2011
    Jul 2012
    3
    Thanks for the quick reply.
    I don't think I know enough about complex lisp routines to determine if I need all three lisp routines and what portions I should modify for my purposes.
    The block in question is named "b-size status stamps".
    Any additional assistance you could provide would be greatly appreciated.
  6. #16
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by qball View Post
    Also, can I select and change all the layers in multiple blocks without Editing the Blocks individually?
    LAYERMERGE might be your friend with this one.
    Drafting is a breeze.
  7. #17
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    I'm also trying to select an object in paperspace across all layouts. But it looks like I'm missing something bc the code doesn't work at all for me. I tried directly copying and pasting MSasu's code from post #12 into the command line which didn't work. A little direction?
  8. #18
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    Quote Originally Posted by eyeofnewt555 View Post
    Code:
    (sssetfirst nil (ssget "_X" '((0 . "INSERT") (2 . "NameOfBlock"))))
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  9. #19
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    Thanks, BlackBox. This appears to work, but for anyone reading this in the future, Grrr has created a more user-friendly version--found here.
  1. I have to shift-select to select multiple objects
    By PDS in forum AutoCAD Beginners' Area
    Last Post: 29th Nov 2011, 08:15 pm
  2. Layout Tabs From Multiple .DWGs
    By Freerefill in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Aug 2009, 06:12 pm
  3. select multiple objects
    By Fried Eggs in forum AutoCAD Beginners' Area
    Last Post: 29th Oct 2007, 06:12 pm
  4. Creating multiple layout tabs
    By Feladris in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Mar 2007, 09:50 pm
  5. Plotting Multiple Layout Tabs
    By O Snap! in forum AutoCAD Drawing Management & Output
    Last Post: 26th Oct 2005, 07:46 pm
