Results 1 to 5 of 5
Thread: bend
    Full Member
    Inventor 2010
    Sep 2009
    34
    Default bend
    I`m not able to add a .3mm fillet to a part containing Bends.What do i need to change so as to get the fillet to work on the entire modelbend.ipt?.Model made with Inventor 2012.
    Cheers
    TBorland
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    I would start by reading this document. http://home.pct.edu/~jmather/skillsusa%20university.pdf
    I noticed that your first sketch isn't constrained - even though you placed at origin. This should be automatic.
    It was also unclear to me where you were trying to add the fillet - I am able to fillet the entire part?
    (pull down EOP in attached file)
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Full Member
    Inventor 2010
    Sep 2009
    34
    Cheers...i was using Loop select
    Would this part be better made with sheetmetal?
    It was the 1st time i use the bend command....does the bend feature always leave segments where the part is bent?
    Tony B
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Quote Originally Posted by TonyBorland View Post
    I would have modeled as-folded to the finished dimensions, probably as a trimmed surface and then Thicken.
    It could also be modeled from sheet metal.
    I would have used either of these techniques rather than the Bend as you did.
  5. #5
    Full Member
    Inventor 2010
    Sep 2009
    34
    OK thanks JD
    If time permits would you be able to give examples of - I would have modeled as-folded to the finished dimensions, probably as a trimmed surface and then Thicken and sheet metal....as mentioned that was the 1st time i used Bend feature so seeing other ways of making Bend features will assist in me modelling better
    Cheers,
    Tony B
    Inventor 2012 EDU
  1. Help) How can I bend a 3d
    By Mr guiff in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Sep 2010, 11:11 pm
  2. How to bend it...
    By nikhil in forum Autodesk Inventor
    Last Post: 25th Aug 2010, 09:36 am
  3. How to bend an object?
    By Crazy J in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Mar 2010, 01:53 pm
  4. Bend Tables
    By robertf in forum Autodesk Inventor
    Last Post: 9th Mar 2009, 11:39 pm
  5. How do I bend a rectangle?
    By jlovgren in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Jan 2009, 06:49 pm
